09-25-2016, 10:11 AM | #1 |
Mounting a Universal Tire
Since Universal tire is most likely closed on Sunday. I'm embarrassed to ask this question here. Both sides of the tire read the same except one side has the lot number stamped in white. The other side has the date code molded into the tire. Date code side out?
Thanks in advance Charley |
09-25-2016, 10:13 AM | #2 |
Re: Mounting a Universal Tire
I would.
09-25-2016, 10:19 AM | #3 |
Thanks Jim, so will I. Now I can get back to work.
Regards Charley |
09-25-2016, 10:44 AM | #4 |
09-25-2016, 04:14 PM | #5 |
The white is just ink which should clean right off... I would put the date code inside... As it looks better that way to me....
