08-27-2015, 06:48 PM | #1 |
Simmons carburetor part need thread size
Gentlemen
Could someone post the thread size on the lower float bowl drain plug? This would be the hole below the float on the cast iron bowl. Would anyone have an extra correct brass plug for sale? Would buy a cast iron Simmons bowl if it has the fitting with it. Thanks in advance. Always give 100% except when donating blood. Charley Last edited by ckulchar; 08-27-2015 at 08:39 PM. |
08-28-2015, 09:43 AM | #2 |
Re: Simmons carburetor part need thread size
It looks like a metric size, close to 6 mm.
08-28-2015, 02:44 PM | #3 |
Has S in top casting where Z appears on Zenith Has S below that in bottom casting, Plug measures 6.09 MM across the threads, with dial indicator, and thread gauge says it is 0.8 pitch. I do not have a metric bolt or tap or Die in that size to verify size. The plug looks like a tall hex head with 6MM .8 threads and is made of steel. Hope this helps ... Last edited by Benson; 08-28-2015 at 03:49 PM. |
