Old 12-01-2013, 01:34 AM   #1
Richard/Ca
Richard/Ca's Avatar
Default where is the no.1 piston
Where is the No. 1 piston suppose to be when the marks on the crank gear and cam gear are perfectly lined up. The top of the piston is down in the cylinder about 1 inch. Getin old i guess Thanks Richard/Ca
Richard/Ca is offline   Reply With Quote
Old 12-01-2013, 08:08 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: where is the no.1 piston
The piston will be at TDC when the pin is inserted in the cover and matches up with the cam gear dimple. So, when the marks on both gears are matched, the piston will be down in the bore but I can't tell you how far.
Old 12-01-2013, 11:48 AM   #3
Gary WA
Gary WA's Avatar
No. 1 front piston will be to the top of the block, remove the 1 spark plug with flashlight look in hole you will see the piston at top dead center, make sure you are not looking at the valve and the dimple should be felt when inserting.
www.whidbeymodelaclub.com
Old 12-01-2013, 12:01 PM   #4
700rpm
700rpm's Avatar
Gary, what you say it correct for the moment the timing pin drops into the indent on the timing gear, but I think Patrick has the right answer to Richard's question.
Ray Horton, Portland, OR
700rpm is online now   Reply With Quote
Old 12-01-2013, 12:36 PM   #5
Richard/Ca
Richard/Ca's Avatar
THank you so very much Patrick L , Gary WA ,700rpm. All great answer but Patrick L's was the one I was looking for. Richard/Ca
Old 12-01-2013, 02:25 PM   #6
Gary WA
Gary WA's Avatar
correct thanks. same answer
Old 12-01-2013, 05:54 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
WHERE'S # 1 PISTON? NOW, thets FUNNY, Richard! Dog here, Chief described a LOOOOSE OOOLD rattley engune, like, "Sounds like the pistones are SWAPPIN' HOLES"!! BUT, I think u'll find thet # 1 pistone is still in # 1 HOLE!!! LOL (# 1 hole is the frunt hole, when sittin' in the driver's seat, lookin' fruntways)-Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 12-02-2013, 05:56 PM   #8
Richard/Ca
Richard/Ca's Avatar
Sorry Bill I Did not ask what hole the #1 piston was in. I ask what was the location of the piston in the hole when the timing marks were lined up. My stuped I guess. Richard
Old 12-02-2013, 06:19 PM   #9
John Stone
John Stone's Avatar
I think Bill was jerking your lariat. He knew what you meant.
John Stone is offline   Reply With Quote
Old 12-02-2013, 09:22 PM   #10
Bruce,Upstate NY
I think some had better reread the initial question.
Bruce,Upstate NY is offline   Reply With Quote
Old 12-02-2013, 11:11 PM   #11
BILL WILLIAMSON
Sorry, Richard, NO you ain't stupid, the Dog jist gits out of kontrol, when I DON'T censor his rattlin'
I "think" your question was, "Where is #1 piston when the marks on the cam gear & the crank gear are aligned"? Maybe I mis- read it?? Bill W.
(Richard, I re-read it. Wherever the piston is, when those marks are aligned, has NO relevance to anything and is NOT important, as far as I know???)
The Dog originally read the question to me, while I wuz unclogging the paper shredder, & I think he mis-read it to me
Old 12-02-2013, 11:22 PM   #12
Richard/Ca
Richard/Ca's Avatar
That alright Bill and the Dog. It had to smile a little when I went back to my message and found that I didn't even spell STUPID right. Sorry! Richard
Old 12-02-2013, 11:56 PM   #13
BILL WILLIAMSON
Shucks, Richard, I'm beginnin' to spel & tipe like that dad burned Dog LOL Well, we need SOME kind uf reputation Meybe thats why NOBODY ever calls??????? The Dog sez I only have 2 friends left, since my good friend, Andy, passed away last week with a HUGE brain aneurysm. The Dog watches his house from the front window, waiting to bark when Andy comes out front. bILL W.
