Old 10-16-2021, 12:44 PM   #1
shew01
shew01's Avatar
Default Red Dot on New Tires
Somewhere (I can’t remember where) I read that new tires often have a red dot painted on them to identify the low balance spot on the tire. If I recall correctly, that red dot should be lined up with the valve stem to help balance the tire.
Am I recalling this correctly?
Also, second question. My new American Classic radials have two red dots that don’t line up with each other. One is on the tread, and the other one is on the back side of the tire. (The white stuff in the pictures is talcum powder.) which red dot should line up with the valve stem?
Old 10-16-2021, 12:50 PM   #2
bbrocksr
Default Re: Red Dot on New Tires
The one on the sidewall.
Bill
bbrocksr is offline   Reply With Quote
Old 10-16-2021, 01:01 PM   #3
Keith True
Keith True's Avatar
When I worked at a tire store in high school the Lee tire rep told us that was an old wives tale.Some have marks for quality control,some for inventory,some from out of the country have marks to show a duty was paid.He said their tires were marked with a blue circle,or dot,when the excise tax was paid.Those blue circles were on the sidewall,and they were handy to use as a reference point when balancing,maybe that's where the rumor got started.
Old 10-16-2021, 01:58 PM   #4
Werner
Werner's Avatar
The red point on the flank indicates the lightest part of the tires. Therefore it should be mounted towards the valve.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-16-2021, 02:30 PM   #5
McMimmcs
McMimmcs's Avatar
Did you ask your supplier ?
Old 10-16-2021, 04:34 PM   #6
ronn
in the retail trade, a red dot signals push money- meaning you get a spiff for selling
older merchandise.
Old 10-16-2021, 06:56 PM   #7
bbrocksr
Correct , It's stated that way in the FAA Airframe manual, that's where I learned it.
Bill
Old 10-16-2021, 08:19 PM   #8
700rpm
700rpm's Avatar
Bill
That’ks what I’ve always been told.
Ray Horton, Portland, OR
Old 10-16-2021, 08:23 PM   #9
Patrick L.
Patrick L.'s Avatar
Whats a flank ?
Old 10-16-2021, 08:25 PM   #10
bavArian
bavArian's Avatar
He meant the sidewall.
bavArian is offline   Reply With Quote
Old 10-17-2021, 06:28 AM   #11
shew01
shew01's Avatar
Yes, I did before posting. (One of the big boy Model A parts suppliers) They didn’t know anything about paint markings at all. I talked to two people.
Old 10-17-2021, 12:37 PM   #12
GRutter
GRutter's Avatar
Tires go through several post production tests.
The first is done on a Tire Uniformity Machine that measures radial and lateral runout. Radial Runout measures the forces created by "less flexible" areas of the tire created by splices in the inner-liner, plies, and tread splices during tire construction. These splices are staggered during construction, but they result in areas where the tire is less flexible, and even if the tire is perfectly round, result in a "feel" that the tire is out of balance because the less flexible areas push back against the suspension more than the more flexible (non-splice) areas. The radial "high point" is marked on the tire near the bead in colored wax.
Lateral runout is also measured. It is a measure of the tire wanting to pull left or right as it rotates.
The next test a tire goes through is either static or dynamic balance. The light spot on the tire is also marked with a wax dot lower on the sidewall (furher away from the bead)
GRutter is offline   Reply With Quote
Old 10-18-2021, 01:05 PM   #13
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Talking Re: Red Dot on New Tires
So I guess this means putting your valve stem centered on the logo is just vain and not a sound practice, balance wise, that is.
Old 10-19-2021, 06:57 AM   #14
Big hammer
I noticed my spare is centered, must have been an accident ! Balance wise, isn't that's what wheel weighs, balance beads, and anti-freeze is for ? I had a first night on the job kid install new tires on my modern, weights 80% around one wheel, loose lug nuts, damaged center hole, 3-4 hours waiting time :-(
get a bigger hammer tap done
