12-02-2019, 01:49 PM | #1 |
What is the gross vehicle weight of 1941 Ford pickup
Registering a '41 Ford pickup and need the GVW, and the source from which the information comes, any help appreciated.
"Get your facts first..then you can distort them as you please" |
12-02-2019, 02:04 PM | #2 |
Re: What is the gross vehicle weight of 1941 Ford pickup
I had a 1940 Ford 1/2 ton pick up that weight 2880 Lbs.
12-02-2019, 02:16 PM | #3 |
From my NH registration Gross weight 4,200 Lbs.
Ford bulletin S2 page 10 shows the weight empty at 2.745 Lbs. these are for a model 11C commercial car pickup.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
12-02-2019, 02:25 PM | #4 |
I also have another '41 Ford p/u which my title (Washington) for it states 2920 lbs. I bought this one with a Nevada title which doesn't state the GVW,,which is the issue Washington has.
I put a call into licensing to see if they will accept the stated GVW from my Washington titled '41..hopefully they will. I will let you know. Thanks for the replies.
12-02-2019, 03:08 PM | #5 |
The DMV called me back and will accept the GVW stated for my other '41 (after I sign a form stating they are identical trucks), so I'm happy with that..crisis averted.
I searched all over the web, in my books, to find the GVW, couldn't find it anywhere.
12-02-2019, 03:26 PM | #6 |
MEMBER EMERITUS
I guess an 85HP V8 41 would be the same. Last edited by swoopNZ; 12-04-2019 at 04:42 PM. |
12-02-2019, 03:51 PM | #7 |
It's interesting that if you put 2 people in the cab and a full tank of gas you are going to be over weight. If the officials ever decide to weigh the pickup or do a quick calculation when you are out and about you could be in trouble.
Tare or curb weight @ 2745 + (2 pers x 180 Lbs) + (17gals x 6.7 Lbs/gal) = 3219. Just be careful. I've had it happen with an OT work truck that was registered using the unloaded weight.
12-02-2019, 04:58 PM | #8 |
How are ya Chuck??....Mark
12-02-2019, 05:00 PM | #9 |
Shoveling snow today. How are things up your way.
12-02-2019, 05:17 PM | #10 |
Didn't 41 pickups have as an option a 4 cyl and maybe even a 6? If so, there could be weight differences.
12-02-2019, 05:28 PM | #11 |
gvw is the total of the truck and its cargo=gross vehicle weight. not what the pickup weighs. most likely the state wants this because thats how trucks are taxed for road use, by the gvw
12-02-2019, 06:30 PM | #12 |
Yes the different engine options for '41 would also present slight variables..that's a can of worms I wish to not disclose to the nice lady at the DMV.
Agreed the GVW comes into play when taxes are priority number one..which is always the case when the state is involved.
12-02-2019, 08:26 PM | #13 | |
11C Ford V-8 2745 lbs. 1GC Ford 6cyl. 2732 lbs. 1NC Ford 4cyl. 2575 lbs.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. Last edited by 41ford1; 12-02-2019 at 08:28 PM. Reason: correct model # |
12-02-2019, 08:30 PM | #14 |
My point exactly.
12-02-2019, 09:51 PM | #15 |
gvw is i believe a relatively new term. back in the day they may have said "load capacity" or something else that would change your search
12-03-2019, 06:00 PM | #16 |
Yup....same here.. that’s how we’ll be spending our free time for the next few months.... take care....Mark
12-03-2019, 10:54 PM | #17 |
My American Light-Duty Trucks book says......1941 112" chassis GVW is 4300 lbs.
The 3/4T is 5400 lbs and the 1T is 6400 lbs. |
12-04-2019, 12:05 AM | #18 |
I had my 41with the flathead in it weighed to get it registered......2600 lbs.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
12-04-2019, 12:42 AM | #19 |
Just a side note.
There are places to find weight of a vehicle. If you're friendly with a rock/gravel yard they can do it for free. DMV should suggest a place. under 2500lbs sound lite to me. Engine alone is in around 600lbs with trans. . Last edited by Tinker; 12-04-2019 at 01:26 AM. |
12-04-2019, 05:34 AM | #20 |
The 4300 lb weight quoted above seems right to me.
I had my truck weighed and it came in at 2650 lbs. Half a ton is 1120 lbs.* So that leaves 530 lbs for driver, passenger and some fuel, tools etc. Or am I doing the sums wrong? Mart. *Damn I just found that Imperial and US tons are different. Still 4300 lbs sounds good to me. |
