Old 05-24-2019, 03:51 PM   #1
jwilliams81
jwilliams81's Avatar
Default How to get that perfect exhaust sound?
How do I get this sound?! It's glorious.
I know that it's full retard, but what other settings get me there?
https://youtu.be/rKwZQqhpYng
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 05-24-2019, 05:36 PM   #2
Werner
Werner's Avatar
Default Re: How to get that perfect exhaust sound?
Sounds like mine! Very much late-ignition and very low RPM. That is all.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-24-2019, 06:09 PM   #3
J Franklin
J Franklin's Avatar
You may need a muffler like Ford used originally. and run it real slow!
Old 05-24-2019, 06:34 PM   #4
Railcarmover
Red's 4 into 2 header open collector..
Railcarmover is offline   Reply With Quote
Old 05-25-2019, 01:08 PM   #5
jwilliams81
What does "very late ignition" mean?
Cincinnati, Ohio
Old 05-25-2019, 01:09 PM   #6
J Franklin
J Franklin's Avatar
Retarded spark.
Old 05-25-2019, 04:58 PM   #7
Patrick L.
Patrick L.'s Avatar
Idle speed and mixture adjustment.
Old 05-25-2019, 06:20 PM   #8
steve s
steve s's Avatar
Use a cheap, repro muffler like most As had when most old timers first heard them, so that's what they think they're supposed to sound like.
steve s is offline   Reply With Quote
Old 05-25-2019, 09:44 PM   #9
redmodelt
redmodelt's Avatar
Sounds like tin can and I don't understand with this obsession with running the motor as slow as that one sounded, it's neat to try but my OP is hard on the engine in the long run not a whole lot of inertia in the flywheel running that slow.
Old 05-26-2019, 12:46 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I agree, and at that low speed just how much oil is being thrown up on the cam and cylinder walls?
Old 05-26-2019, 02:17 PM   #11
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
At 350 rpm, I’m pretty sure oil is flying!
Old 05-26-2019, 02:35 PM   #12
chap52
chap52's Avatar
Sounds cool for idling but we all know that the spark will have to be advanced to get on down the road. Sometimes when I pull into a parking space I will put both levers up and the result is that "sweet Model A" idle. Also, I always put the spark lever up when parking so I don't forget to do so for the next start. Chap
Old 05-27-2019, 08:02 AM   #13
daren007
My wife doesn't think much of my exhaust sound.
daren007 is offline   Reply With Quote
Old 05-27-2019, 08:58 AM   #14
1928Mik
1928Mik's Avatar
Yep, Werner and JFranklin are correct. Get your timing right first. Then shove that lever full retarded and set your idle speed as low as it will go. That's it. I remember my Dad and his buddies would do that and then stand around and marvel how well the motor purred at that level. They always said that was the sound of a well-timed engine.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
