08-06-2022, 09:31 AM | #1 |
Any V12 guys?
Asking for a friend…..what is your spark plug recommendation for 1940 V12?? Or what you’ve found runs the best?? AND or is it better to have one slightly hotter than recommended???
08-06-2022, 04:36 PM | #2 |
Re: Any V12 guys?
In general for a flathead that that is not pushed very hard, one range hotter plugs may be a little less likely to foul, when puttering around town in traffic. I would not fret over the choice.
08-06-2022, 04:44 PM | #3 |
Re: Any V12 guys?
Not much help, but the Pierce-Arrow derived V12 in my '48 Seagrave fire engine took Champion H10's. They worked great in it. The only problem was that with dual ignition, it took 24 spark plugs. I ran every hardware and lawn and garden store within 20 miles out of plugs when I changed them.
08-06-2022, 07:39 PM | #4 |
Re: Any V12 guys?
Spark plugs can be a back and forth item. Different folks have different opinions about manufacturers. The V12 Lincoln engine can use the same plugs as the Ford L head V8. There are a lot of threads on here about spark plugs.
If it was made by Ford it is welcome in the barn. Ford made B model 4-cylinder engines, V8 60 engines, N model tractor 4-cylinder engines, 85 & 95 HP V8 engines, and 90-HP G series 6-cylinder engines even before WWII started. The Lincoln and Mercury cars are popular cars on here too. |
08-06-2022, 08:07 PM | #5 |
Re: Any V12 guys?
If the V12 does indeed take the same plug as its V8 brethren, the popular modern replacement for a Champion H10 is a the NGK B4L. Hotter version is the B6L.
08-07-2022, 07:11 AM | #6 |
Re: Any V12 guys?
Pm message sent. |
