Old 06-27-2022, 10:23 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 1939 Deluxe Window Crank Escutcheon Set Up
So recently acquired 39 Deluxe Coupe.
Window winders not fitted. See attached picture. My question is does the smaller round piece sit atop the larger piece or does it sit inside it.
On backside of smaller piece are 4 small tags which line up with the holes in larger piece.
Appreciate all advice with this one.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 06-28-2022, 12:06 AM   #2
restoman
Default Re: 1939 Deluxe Window Crank Escutcheon Set Up
Those are not 39 DeLuxe escutcheons. The right ones are one piece and have been widely available as reproductions,
restoman is offline   Reply With Quote
Old 06-28-2022, 09:23 AM   #3
Phil Gillespie
Just to clarify, the one at left hand side was in the glove box of the car.
From pictures I presumed it was missing so ordered the one on right hand side from Michael at 3rd Generation. I believe these are correct for 39 deluxe by part No: 91A-7022618!! Or am I missing something here? Both door window escutcheons were missing.
Deluxe is new to me as I am used to 39 standard.
Phil NZ
Old 06-28-2022, 10:12 AM   #4
marko39
If it matters to you , the correct handle is dark bronze. The one in your post looks like chrome.
marko39 is offline   Reply With Quote
Old 06-28-2022, 10:47 AM   #5
Phil Gillespie
Just the light it is dark bronze. Its the escutcheon I am asking about.
Phil NZ
Old 06-28-2022, 10:49 AM   #6
Kube
Kube's Avatar
Phil, does this help?
Old 06-28-2022, 11:31 AM   #7
Phil Gillespie
Kube thanks for that. Have studied the 39 Book but also hard to pick up from there. This is an original un-restored car and wish to do it justice.
There are marks on door card which suggests the left hand piece due to larger diameter was fitted to these doors.
Phil NZ
Old 06-28-2022, 11:41 AM   #8
marko39
The one on the right looks like the right one.
Old 06-28-2022, 11:52 PM   #9
Phil Gillespie
The one on right is what I purchased from 3rd Generation. Was there a spring fitted in behind these?
Phil NZ
Old 06-29-2022, 07:05 AM   #10
marko39
there was a spring to keep it snug but it makes installing handle harder. (need that nifty tool drake sells) mine fits fine without the spring.
Old 06-29-2022, 11:32 AM   #11
Phil Gillespie
Tried for tool but 3rd Generation out of stock. Will maybe go without spring as you suggest. Door handles dont have one fitted.
Thanks
Phil NZ
Old 06-29-2022, 12:11 PM   #12
TJ
TJ's Avatar
Thanks
Phil NZ
The spring goes behind the door panel. You may or may not need one or if you have a nice original car it may already be there.
Old 06-29-2022, 12:50 PM   #13
marko39
Learned something new, no wonder I gave up trying to fit it under escutcheon.
Old 06-29-2022, 01:38 PM   #14
Phil Gillespie
Thanks so much for that good piece of info. Something I was totally unaware of. Just got to keep on with the learning.
Phil NZ
Old 06-29-2022, 04:44 PM   #15
swoopNZ
MEMBER EMERITUS
Phil,
I have a couple of door panel springs you can have - gratis.
Chris.NZ.
06 755 0818
swoopNZ is offline   Reply With Quote
Old 06-29-2022, 08:00 PM   #16
Phil Gillespie
Originally Posted by swoopNZ View Post
Phil,
Chris.NZ.
06 755 0818
Appreciate your very kind offer.
Many thanks
Phil NZ
Old 06-29-2022, 08:56 PM   #17
Kube
Kube's Avatar
Phil NZ
redundant post
