05-09-2022, 11:58 AM | #1 |
Lincoln Brakes
I have been hoping to find the parts needed to convert to Lincoln juice brakes. I believe that I have found a set but i need to know, will these work with my stock spindles and front and rear hubs?
05-09-2022, 12:09 PM | #2 |
Re: Lincoln Brakes
Hello, my car has the Boling brothers conversion on it , was on it when I bought it, looks like they had to do some fitting on the kingpins and rear axle shackle area to get the back plates to fit. Hopefully others that have installed a set will join in .
05-09-2022, 12:12 PM | #3 | |
Re: Lincoln Brakes
We would probably need to know at least what year Lincoln brake parts that you have found, as there are differences. You also mentioned "working with your stock spindles & hubs". Were you thinking about using Lincoln drums on YOUR Model 'A' hubs? Model 'A' brakes are 11", whereas the Lincolns are 12" diameter. Exactly what were you thinking about replacing/modifying? Coop . |
05-09-2022, 01:36 PM | #4 |
Re: Lincoln Brakes
Boling brakes are sold Krylon at a 10% discount. He posts on the EV8 Forum. I think you'll have to change the front spindles.
Paul in CT |
05-09-2022, 04:42 PM | #5 |
Re: Lincoln Brakes
They provide a spacer for a seal in the hub. I have their fronts on my Tudor and Ford rears. Works well with good braking balance front to rear. Ps. Do have to grind a relief in hub flange for the front wheel cyls. John
Welcome each day |
