04-28-2022, 07:23 PM | #21 |
Re: 90 degree oil filter adapter
i will report back on it once it shows up here and i have it mounted or at least tried to mount it
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
04-28-2022, 08:25 PM | #22 |
I previously saw that another adaptor 97JM6884AA will also work. This adaptor was used on the 97 and 98 Ford Explorer, 4.0 L motor. The auto junk yard had ten explorers so it was easy to find. You do have to remove the exhaust first to access the bolt that holds it to the block. The bolt with the adaptor will thread into the valve cover from the oil filter kit sold by most A vendors. You will have to remove the nipple that is used with the valve cover. I put it on the motor today, it fits fine.
Thread Tools | |
Display Modes | |
