Old 01-24-2021, 06:30 PM   #1
pjdeb
pjdeb's Avatar
Default Battery/Starter Advice Needed
I have been focusing my headlights. So the battery was drawn down. Battery is two years old. When starting the A, the starter whirls, but does not engage.
Recharged the battery. Read 6.2 volts. Starter whirls and still does not engage. Crank started and went for half hour ride. Back in the garage. No go.
Before pulling the starter to look at solinoid or bendix, thought I would ask for some advice. I am not an electrical engineer. Could it be that battery voltage is OK, but it is not delivering enough cranking amperage?
Grounds are tight and clean.
Thanks
pjdeb is offline   Reply With Quote
Old 01-24-2021, 06:48 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Battery/Starter Advice Needed
Could be even tho battery says 6.2 V, May not be, I went thru three batteries in a week with the same results. Says good but not. Changed to NAPA battery- All is good. Take it to a reliable supplier and they can put a load test on it,right after you think it may be charged.
www.whidbeymodelaclub.com
Old 01-24-2021, 06:50 PM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Broken bendix spring. No big deal. Easy fix.
Jacksonlll is offline   Reply With Quote
Old 01-24-2021, 06:57 PM   #4
Oldgearz
Agree. Sounds like bad Bendix.
Oldgearz is offline   Reply With Quote
Old 01-24-2021, 07:00 PM   #5
Ivan in southeast va.
Ivan in southeast va.'s Avatar
You will have to remove starter. Easy fix.
Ivan in southeast va. is offline   Reply With Quote
Old 01-25-2021, 10:44 AM   #6
JBill
If it does turn out to be the bendix, make sure you get any debris (like a broken bolt, e.g.) out of the flywheel housing--if there is any debris. Might not be. Lots of advice on this board on how to get stuff out of there. Magnets, gobs of grease, etc.
JBill is offline   Reply With Quote
Old 01-25-2021, 08:53 PM   #7
pjdeb
pjdeb's Avatar
Well, it has been a learning experience, anyway. Removed the starter. Expected to find broken bendix spring. Looks good. Am I missing something in the attached picture?
Back on the idea that although battery voltage tests OK, battery is weak.
Starter whirs but does not engage.
Thoughts?
Old 01-25-2021, 09:07 PM   #8
Aarongriffey
When you run the drive gear in as close to the starter as possible can you turn the starter with the drive gear?
Aarongriffey is offline   Reply With Quote
Old 01-25-2021, 09:18 PM   #9
[email protected]
modela@aol.com's Avatar
Thoughts?
Where is the second bolt holding the bending spring?
modela@aol.com is offline   Reply With Quote
Old 01-25-2021, 09:37 PM   #10
J Franklin
J Franklin's Avatar
Yes, a broken or missing bolt. Don't buy a new battery until the old one won't work any longer.
Old 01-25-2021, 10:52 PM   #11
pjdeb
pjdeb's Avatar
Oh yes! Bolt broken off. Now I have to find it. Looks like I have to go fishin'.
Old 01-25-2021, 11:10 PM   #12
Mister Moose
Mister Moose's Avatar
more info needed.
Does the whirring stop, ie battery cant crank once bendix has engaged flywheel?
Does whirring continue, bendix not engaging?
Is whirring too slow, and not spinning fast enough to send bendix out?
You could have a little of both.
On the battery, measuring voltage right after charger disconnect is almost pointless. The battery will have excess surface charge. You need to let the battery rest with no load and measure voltage 24 hrs later. I forget the exact numbers, but 6.2 is not impressive. 6.35 is more like full charge. Little voltage differences matter, another reason specific gravity is a better test.
A very good tester is a specific gravity tester, looks like turkey baster. Not expensive, and gives accurate state of charge and battery health.
With an SG tester, you also can test all 3 cells, all should be close. One low cell indicates sick battery. Careful handling the electrolyte, its a strong acid. wash hands and rinse tester afterward. careful with errant drops.
Load test is good too.
Mister Moose is offline   Reply With Quote
Old 01-26-2021, 09:28 PM   #13
01A
01A's Avatar
Your battery may have a poor ground connection. Try cleaning the battery post connections and especially the ground connection to the frame. That took care of a similar starting issue I had.
01A is offline   Reply With Quote
Old 01-26-2021, 10:24 PM   #14
Purdy Swoft
Purdy Swoft's Avatar
Oil on the helix of the starter drive will cause the starter to spin , but not engage . .
