05-28-2021, 12:10 PM | #341 | |
Re: The Terry Burtz 5 main bearing engine blocks are back on track.
The good ole' USA isn't down and out yet! |
05-28-2021, 01:16 PM | #342 | ||
05-29-2021, 06:27 AM | #343 | |
05-29-2021, 06:28 AM | #344 |
05-29-2021, 06:44 AM | #345 |
What is the benefit of fresh air in the crankcase?
05-29-2021, 07:12 AM | #346 |
05-30-2021, 08:50 AM | #347 |
Positive Crankcase Ventilation removes blow-by gases, water vapor (byproduct of combustion and condensation), and fuel vapors (from cold starts). This helps reduce sludge formation. It also helps people feel good about their modification.
One thing often overlooked is that the air entering the crankcase should be filtered. Otherwise you are drawing dust into your crankcase. The original vent cap is not a very good filter. |
05-30-2021, 10:08 AM | #348 |
I can see that a Model A might not be made for crankcase vacuum. I don't think that engines that use pcv valves and such have paths for fresh air to enter, though.
06-02-2021, 09:33 PM | #349 |
The "New Engine Kit" along with an original cylinder block, crankshaft, and connecting rods will be on display at the MARC National Convention in Oshkosh, WI.
We will be in the B.F. Carter Room that is across the hallway from the Hospitality Room and I will be happy to answer any question or discuss any concern. A modified Model A oil pump that delivers increased volume, builders guides, Secrets of Speed Magazines, and several other parts that I manufacture will be on display. On Friday afternoon, June 11, I will give a seminar on the "New Model A Engine Kit". Dennis Kliesen has assembled an engine using the "New Engine Kit", has driven over 2000 miles traveling to Oshkosh, and will be there to tell you about his trip and answer questions. Another "New Engine Kit" is in car #35 for the Great Race and has accumulated about 1000 miles. One "New Engine Kit" using a "Miller Hi-Speed" head was tested on a dynamometer and it developed 170 lb-ft at 2800 RPM, and 110 HP at 3300 RPM. Please bring your questions, concerns, measuring equipment, and mating parts for fit checks. In preparation for Oshkosh, please see www.modelaengine.com |
06-03-2021, 02:58 AM | #350 |
When is the next engine shipment going to be available?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-11-2021, 08:59 PM | #351 |
The next shipment is currently in production and should be available in the US by early August. Ocean freight schedules are still somewhat unpredictable though. We'll have more info in early to mid-July.
06-12-2021, 02:33 AM | #352 |
Hi Guys,
just wondering if some one who has a new engine running using a Stipe oil pump can you please tell me what oil pressure they are producing, using 35/40psi or 50/55psi pressure relief valve spring, and also if they have had to reduce oil pressure at all? |
06-12-2021, 08:34 AM | #353 |
I have the new Terry Burtz engine with a Stipe pump and have the lower relief green spring installed in the pump. I also have a external adjustable relief made by Scat Volkswagen. I have the pressure lowered to reduce strain on the pump drive and camshaft gears. I have over 2800 miles on this engine since it was built and no problems.
06-12-2021, 10:50 AM | #354 | |
The Engine has a Miller OHV Conversion, We hame an Earl’s Remote Adapter with a WIX 51085 Filter, the adapter has an 1/8 NPT output that oils the head, and we use Valoline VR-1 20W-50 oil. There is no internal or external pressure adjustment. The engine runs with just over 30 PSI Oil Pressure, at start up, running warm, and at idle a when warm (165 degrees) pressure is just over 20, maybe 22 PSI. |
06-13-2021, 01:50 AM | #355 |
Hi dennisklisen, thanks for your reply, what oil pressure did you have prior to using the Scat adjustable relief set up and what oil pressure do you have now?
Regards Pete |
06-14-2021, 08:16 AM | #356 |
Pete, I had 40+ psi @2200 rpm warm oil. About 35 psi at 1500 rpm warm oil. With the Scat Volkswagen adjustable external valve I have 20+ psi from idle increasing to cruising speed 60+ mph. At a slow idle the pressure with warm oil is about 10 psi. There are 2 different plungers and 2 springs that are included with the adjustable valve package. I think it works much better with the plunger than a ball bearing on the seat as some have tried using. The pressure setting is consistent with a plunger. You might have to find a different spring than what is included to achieve the desired pressure setting. The adjustment screw only has about 1/4” of adjustment. The nut on the adjustment screw to lock the screw leaks unless a modification is made to incorporate the use of an oring. It’s a matter of trying different springs to get that desired pressure requiring a lot of time and patience. It’s not a perfect solution but I was able to accomplish what I wanted without dropping the pan and fiddling with the relief in the pump. Make sure you have the green spring in the Stipe pump if you are trying to get a lower relief setting. The primary reason for lower pressure was to reduce the amount of strain on the pump drive gear and the camshaft gear.
06-14-2021, 08:18 PM | #357 |
Thanks for the info Dennis, I have just about finished assembling my new engine, I am using the Stipe oil pump with the 35-40psi pressure relief spring. Unfortunately Scat will not send parts to Australia as our government want them to collect and remit a goods & services tax. What I have done is install an adjustable needle valve with a tee piece splitting the main oil return pipe out of the oil filter diverting any excess oil pressure into the side plate, sorry I cannot attach a photo, too dam hard.
06-14-2021, 08:44 PM | #358 | |
I'll get it and send it to you. You can pay me when you get it if you like. Paul |
06-15-2021, 04:29 AM | #359 |
Hi Paul,
thanks for your generous offer, but the set up I have done will relieve any high oil pressure issue that I more than likely will have in my new engine. Pete |
06-18-2021, 05:39 PM | #360 |
Hey Terry,
Yesterday picked up my Burtz flywheel. Nicely machined ! Question… is the pressure plate bolt hole pattern … for a 9 inch 50s pressure plate. Standard ring gear use and crank bearing ?? Nice piece of heavy metal… well done ! |
Thread Tools | |
Display Modes | |
