Old 05-16-2022, 05:17 PM   #1
shew01
shew01's Avatar
Default Grease Fitting Will Not Take Grease
I’m greasing the chassis today, and the fitting on the interior side of the front brake backplate (by the king pin) will not take grease. This is a surprise because I grease the chassis every 1000 miles, which turns out to be about 3 times a year, and all of the fittings took grease fine last time.
I used a toothpick to make sure there isn’t any debris in the fitting, and I’ve tried a little bit of torch heat with no luck. I don’t want to get carried away with the torch and mess up the hardening of the metal.
Can anyone offer me some ideas for how to proceed?
Old 05-16-2022, 05:30 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Grease Fitting Will Not Take Grease
I assume you have the front end lifted off the ground. If not, you are fighting the weight of the car to force grease in there. Another possibility is that the bush has turned in the stub axle, causing the holes to no longer line up. Disassembly is the only cure if that is so and that might be good idea anyway to make sure all is well.
Old 05-16-2022, 05:53 PM   #3
shew01
shew01's Avatar
Yes, the wheels are off the car.
Old 05-16-2022, 06:00 PM   #4
shew01
shew01's Avatar
I’ve never had a king pin out of a car. I didn’t know there was a grease hole in the bushing, but I guess that would make sense. I didn’t know the bushing could twist either.
Old 05-16-2022, 06:29 PM   #5
Synchro909
Synchro909's Avatar
Like most things on these cars, king pins are not difficult to work on. If you have either Les Andrews' or Les Pearson's book, there are simple to follow directions. (I prefer Pearson's book)
Old 05-16-2022, 06:43 PM   #6
shew01
shew01's Avatar
Found it. Wow. My Model A grease fitting adapter was plugged. I had a second adapter, and the grease fitting takes grease just fine with it. I never had that happen before.
Old 05-16-2022, 06:46 PM   #7
shew01
shew01's Avatar
I ruptured the grease gun hose trying to get what turned out to be a bad adapter to work, but the grease gun is 30+ years old. So, it’s time for a new hose anyway. I had a new spare.
Old 05-17-2022, 10:45 AM   #8
katy
katy's Avatar
I ruptured the grease gun hose trying to get what turned out to be a bad adapter to work, but the grease gun is 30+ years old. So, it’s time for a new hose anyway. I had a new spare. Sent from my iPhone using Tapatalk
Suggest that you get a longer hose, makes greasing easier.
Old 05-17-2022, 01:31 PM   #9
1931 flamingo
1931 flamingo's Avatar
If you remove the fitting will it take grease?? If no, replace the fitting.
Paul in CT
Old 05-17-2022, 02:19 PM   #10
tobby
purchase a K-D tool number #416 fill it with oil hit it with a hammer and the fitting will be clear, ready for the grease gun, if old hard grease is the problem...........
tobby is offline   Reply With Quote
Old 05-17-2022, 09:18 PM   #11
burner31
burner31's Avatar
Currently out of stock
About $18 when you can find them
Keith
Shawnee OK
'31 SW 160-B
Old 05-18-2022, 04:18 AM   #12
shew01
shew01's Avatar
Interesting tool. I never knew about it. Google found this link when I searched for KD tool #416.
https://www.autotoolworld.com/Gearwr..._p_253188.html
Old 05-22-2022, 08:57 AM   #13
shew01
shew01's Avatar
That sounds like a good idea. How long is the hose that you use?
Old 05-22-2022, 10:14 AM   #14
katy
katy's Avatar
I had to go out to the shop to measure, 24". Stock item, they come in various lengths
Old 05-22-2022, 12:41 PM   #15
shew01
shew01's Avatar
Thanks. I think my old hose was 18”, and my new one is 12”. As I was pumping the fittings with the 12” hose, I was thinking this was harder than I remembered. The longer hose will probably fix that.
