Old 12-03-2020, 08:20 PM   #1
Slowmotoring
Slowmotoring's Avatar
Default Blocked off coolant port above serial number?
Just took of the head to replace the head gasket. When i got the head off i noticed a “pile” off gunk setting on the head gasket just above the serial number. The head has a coolant port in that location but the gasket and the block does not and it is visible in the block that the port was once there. Does anybody know the reason for this?
Slowmotoring is offline   Reply With Quote
Old 12-04-2020, 08:51 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Blocked off coolant port above serial number?
A photo is necessary to give you some good feedback.
Bob Bidonde
Old 12-04-2020, 09:15 AM   #3
jetmek
There is no water passage in the block there
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 12-04-2020, 11:15 AM   #4
TwoDeuceCoupe
If it is the one I am thinking of ....
Actually there is a large oblong passage way between the head and the block which was added in October of 28 or 29 for additional cooling.
TwoDeuceCoupe is offline   Reply With Quote
Old 12-04-2020, 11:33 AM   #5
alexiskai
alexiskai's Avatar
I've attached a photo of a head with the hole you're talking about circled. It's true that there's no corresponding hole in the gasket or the block there, and gunk does tend to accumulate. I don't know why this hole is in the heads, but it's in all of them, even aftermarket HC heads.
File Type: jpg Screen Shot 2020-12-04 at 11.29.55 AM.jpg (19.5 KB, 92 views)
Old 12-04-2020, 11:45 AM   #6
alexiskai
alexiskai's Avatar
You can see in the attached service bulletin that this is a different passage than the one he's referring to. You can also see that the passage he's talking about is present on the head but not on the gasket. It's the only one that doesn't match. Very weird.
File Type: jpg Screen Shot 2020-12-04 at 11.42.38 AM.jpg (16.2 KB, 98 views)
Old 12-04-2020, 12:36 PM   #7
abachman3
abachman3's Avatar
It perhaps has something to do with the casting process. Just a guestimate on my part.
abachman3 is offline   Reply With Quote
Old 12-04-2020, 12:36 PM   #8
Will N
Will N's Avatar
I suspect that hole is there to aid in the removal of the casting core material.
Will N is offline   Reply With Quote
Old 12-04-2020, 04:47 PM   #9
Slowmotoring
The hole circled is the hole i was referring. I tried to upload a picture with original post but it didnt work. Thanks for the thoughts! Wasnt sure if i had a mismatch of some sort.
