Old 11-08-2020, 04:07 PM   #1
Steve Plucker
Default Reproduction Shock Absorbers
How many different types of reproduction Model A Ford shock absorbers have been reproduced over the years?
How can one distinguish one type from the other?
Are any better than the others?
Thanks.
Pluck
Old 11-08-2020, 07:39 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Reproduction Shock Absorbers
I have set made by Rick's Model A parts back in the 90's. Brass housing and leak oil like a sieve.
Mike Peters is offline   Reply With Quote
Old 11-09-2020, 06:38 AM   #3
Benson
Benson's Avatar
I have a set of shocks that I bought new in the 70s or 80s.
I will have to look at them again to tell you of any markings.
Weather went cold on us here so it might be a while.
As I remember the patent info mentions Chicago, Ill
Benson is offline   Reply With Quote
Old 11-09-2020, 07:25 AM   #4
Gene F
Gene F's Avatar
They never last. I switched my A over to the oil filled tube shocks that the late RainmakerRon (Ron Cloat) sold. I am not sorry one bit. But then again, I drive my A. Some people are purists, but they tend to be the ones that only drive 50 - 70 miles a year.
Gene F is offline   Reply With Quote
Old 11-09-2020, 07:38 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
I have a set of repro Houdailles on my Coupe made by Pete of Chicago. They have been on the car since the 1980s, but I had to fill them with a high viscosity oil to compensate for wear. These shocks will be replaced by modern telescoping shocks.
Bob Bidonde
Old 11-09-2020, 08:04 AM   #6
Mike Peters
I misspoke. The shocks I was referring to were also made by Pete of Chicago. Not Rick. He was also known as "Pete the Vendor". Sorry for confusion.
Old 11-09-2020, 08:11 AM   #7
rocket1
Bought a set in the early eighties from a Hershey vendor in the blue field he had a small stand do not know who made them.
rocket1 is offline   Reply With Quote
Old 11-09-2020, 12:26 PM   #8
700rpm
700rpm's Avatar
Pluck, I don’t know about “over the years”, but I put a set of Stipes on my coupe five years ago and they are great! I also had a set of rebuilds from John Holland (if I remember that name correctly — it was over ten years ago) on my pickup and they were also perfect.
Ray Horton, Portland, OR
Old 11-09-2020, 01:18 PM   #9
Ed in Maine
I also have a set of Stipes on my 1932 Coupe and love them. No leaks. Ed
Ed in Maine is offline   Reply With Quote
Old 11-10-2020, 04:07 PM   #10
jak
Currently you have three different companies making reproduction shocks
Bratton's
Stipe
Snyder
In the past you had at least these two
Pete's
M&S Hydraulic
jak is offline   Reply With Quote
Old 11-10-2020, 04:32 PM   #11
arnhemmer
Stipes, no problems whatsoever.
arnhemmer is offline   Reply With Quote
Old 11-10-2020, 04:33 PM   #12
Steve Plucker
Bratton's
Stipe
Snyder
Pete's
M&S Hydraulic
Thanks Jeff,
So to ID each one of those...what would be the tell-tale signs of each?
The four that I have , have the two Patent numbers on top then below those numbers it says Hydrolic Suspension on the face of the cap.
Thanks.
Pluck
Old 11-10-2020, 04:52 PM   #13
WHN
In the early 80’s I purchased a set of shocks from Mac’s. They were made by Superior. Almost 40 years and fingers crossed, not problems. They look and are marked like originals.
Enjoy.
WHN is offline   Reply With Quote
Old 11-10-2020, 05:03 PM   #14
Benson
Benson's Avatar
I spoke to Steve Becker.
Pete Busiac made shocks from the late 70s until 1988.
They say Chicago, ILL as opposed to originals which say Buffalo NY.
Steve said some of these had brass housings and worked quite well for awhile BUT wore out after some usage and started to leak.
Old 11-10-2020, 08:38 PM   #15
KR500
KR500's Avatar
Steve, If you watch the DVD Alex Janke did on shocks he gives a fairly good history of who were the players in the repro shock game. Interesting he mentions Ford paid $1.00 each for the Houdaille shock and attachments for the A.
KR500 is offline   Reply With Quote
Old 11-12-2020, 01:00 PM   #16
Dan Partain
Dan Partain's Avatar
I'm posting this for Pluck.
I would like to know just what type or brand it is...I got four of these.
Thanks.
Pluck
Dan Partain is offline   Reply With Quote
