11-05-2020, 09:04 AM | #1 |
Model A Ford Trunks, WWIRZ Suggestion
Posts: 710 Re: Model A Ford Trunks (Suggestion from WWIRZ) A few weeks ago I mentioned that I was making a trunk for my Victoria and was having trouble with the curved portion of the top. There was a suggestion from WWIRZ to cut strips to form the curve. This suggestion "hits the nail on the head!" The suggestion was to cut the strips with a 12 degree chamfer. The next day I set up my radial arm saw for the twelve degrees and cut (8) strips with the top of the strip at 9/16 in. and the bottom at 7/16 in. In the setup this is what I ended up with after setting up the saw and I decided to stay with this setting. I think the strips may have fitted a bit tighter with a 10 degree chamfer for the curve that I had but the glue filled any gaps. It was an excellent suggestion and the trunk is moving toward assembly. I think my total cost is going to be about $130.00. The trunks I have seen advertised go for about $450.00 and higher. Thanks again Ford Barn for such a good suggestion. Ed |
11-05-2020, 12:21 PM | #2 |
Re: Model A Ford Trunks, WWIRZ Suggestion
This sounds like a really interesting project!
May I ask if you have pictures posted somewhere on here? Sent from my E6810 using Tapatalk |
11-05-2020, 10:47 PM | #3 |
Ed, your a Senior Member...... you know that pictures are 3/4 of the "Barn" fun and instructions are the other 1/4. We are all waiting to see pictures of this project............. were waiting................ are ya taking pictures???
Lots of interest................... |
11-06-2020, 08:33 AM | #4 |
