Old 10-28-2020, 07:31 PM   #1
Sparta
Default Water pump is tough to spin. Normal?
Hey guys! My two blade fan exploded so I had to remove my water pump to replace it. Upon removal, I noticed the pump spins but not very freely. It’s needs a bit of pressure to spin it. Front bearing looks rather new. Is this normal? Thanks!
1931 Ford Model A Tudor
Complete stock rebuild
Disregarding the constabulary since 1931
Sparta is offline   Reply With Quote
Old 10-28-2020, 08:34 PM   #2
Brentwood Bob
Default Re: Water pump is tough to spin. Normal?
There is a pointed washer that nests between the impeller and the water pump housing.
It could be out of position and binding. Take the waterpump apart, and rebuild it.
Should not be any binding, as you describe.
Brentwood Bob is offline   Reply With Quote
Old 10-29-2020, 07:21 AM   #3
kenparker0703
...as brentwood bob said above "rebuild it". When the fan exploded did it bend the WP shaft. Better check it. ken
kenparker0703 is offline   Reply With Quote
Old 10-29-2020, 10:50 AM   #4
Bob C
I think the packing would keep it from spinning freely.
Old 10-29-2020, 04:39 PM   #5
Synchro909
Synchro909's Avatar
"A bit of pressure to turn it", Binding", "Turn freely" are very subjective terms. There may be nothing wrong with the pump, just the owners expectation of what it should be like. IMO, if it was working well before, it will work well now so leave it alone. As Bob C said, the gland packing would prevent it spinning "freely". I suspect there is nothing wrong with it.
Old 10-30-2020, 08:24 PM   #6
31Abone
31Abone's Avatar
Get a leakless and throw that orig ford crap in the ditch
31Abone is offline   Reply With Quote
Old 10-30-2020, 10:57 PM   #7
J Franklin
J Franklin's Avatar
Some people like to do restoration work without modification. The original pump was a good pump.
Old 10-30-2020, 10:59 PM   #8
Synchro909
Synchro909's Avatar
And some of the "leakless" pumps are pretty ordinary, IMO.
