01-30-2017, 11:33 AM | #1 |
Sidemounts - 1 or 2 ?
I have a 30 Town Sedan. I am thinking of switching from the rear mount spare to a side mount. Are most of the sedans that are fitted with side mounts have 1 or two? On the pictures that I see you only see one side of the car at a time. I have a roadster with two.
Is there something in the written materials that offers some guidance? Vic |
01-30-2017, 12:45 PM | #2 |
Re: Sidemounts - 1 or 2 ?
They were dealer installed. One or two is up to you.
01-30-2017, 12:50 PM | #3 |
Some tires have to have the air let out to get the tire out of the fender--Firestone is one brand, so it could be more for show than useful
01-30-2017, 01:06 PM | #4 |
Yes, you would have to use the smaller tire, or let some air out. We all have pumps so it's not a big deal. Maybe they make them bigger now.
01-30-2017, 01:10 PM | #5 |
Depending upon your personal size, as well as your usual passenger(s), you might want to reconsider installing side mounts. The door check straps have to be shortened so that the tire in the fender doesn't dent the opening door. This reduces the entry clearance considerably. It's worse in an open car than a closed one, but there is significantly less entry room once the conversion has been made. This is tough on - shall we say - slender-challenged folks.
You might want to find someone locally with a similar body style and side mounts to see if you really want to make the switch. It's not cheap or easy to do this, either! Consider that in addition to drilling holes in the side splash aprons for the mount arms, you'll also have to hack up the fender itself to install the wheel well. Of course, you could simply replace the entire fender with one that already has a well installed, but now you're REALLY talking big bucks! Plus, you'll have to re-paint each welled fender after installing the well. It's almost impossible to install a well without messing up the fender's paint, sometimes even some additional body work needs to be performed around the well area. Marshall Last edited by Marshall V. Daut; 01-30-2017 at 03:50 PM. |
01-30-2017, 01:16 PM | #6 | |
01-30-2017, 01:39 PM | #7 |
Also not real easy to work on either side of the engine.....
01-30-2017, 02:08 PM | #8 |
My 31 Town Sedan has a right side mount, but I'd be glad if it was on the rear instead. On some large luxury cars I like the side mounts, but for the cheaper basic cars I like the rear mounted spares.
01-30-2017, 02:16 PM | #9 |
I would vote for "zero" side mounts. On a Pickup, there's not a whole lot of choice. I could re-locate it somewhere else as has been suggested many times here, but I really don't want to take on the task of a new fender, etc.
As to the tires fitting in the fender well, I would concur with the above remarks about the Firestones not fitting well. However when I got my Coker Radials (5.50x19) I was pleasantly surprised that they just slipped right in with no problem at all -- fully inflated.
01-30-2017, 02:45 PM | #10 |
I too vote 'no' on side mounts.
I much prefer the look of a Model A Ford without them. On '30-'31 Roadsters, I like the looks of the factory photo of the'31 Dlx. with the REAR mount 10X better than the '30 Dlx. with the side mount. On a sedan they just look 'out-of-place' to my eye. Our Roadster has dual side mounts and I hate them. Everybody and their brother-in-law in the 70's (when ours was first rebuilt) restoring Roadsters, lathered them up with dual side mounts. And cowl lights. Cowl lights on a '30-'31 OK on a '28-'29 NOT OK. Our side mounts rattle and make extra racket. Forget putting the rear view mirror 'option' on one that is another waste of your time and money. They vibrate so badly there's no way they are useful. Plus if you stay with the stock lug set-up you will mar the paint on that newly re-painted fender wrestling the thing in and out. Do as Marshall suggested. Go climb in and out of another's car w/ S.Mounts for a while, and you'll probably change your mind. Side Mounts look great on a Packard or Cadillac or Lincoln from that era. A Model A Ford 'ain't' no Cadillac-Packard-Lincoln. Last edited by Jeff/Illinois; 01-30-2017 at 02:57 PM. |
01-30-2017, 03:19 PM | #11 |
When I was younger about 40 years ago, I like rumba seats in my roadster and coupe. Now I would like the trunk much more.
01-30-2017, 03:23 PM | #12 |
31 tudor with dual sidemounts, I have no trouble with the doors or working on the engine. FWIW
Paul in CT |
01-30-2017, 03:26 PM | #13 |
The preference of side mounts and trunks vs rumble seat is discussed frequently.
Most of today's vehicles have trunks and some still have rear mounted spares. If you have a side mount (one's enough) and a rumble seat, consider that you have something unique to the era. I like having both. Your preference, of course.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
01-30-2017, 03:49 PM | #14 |
I vote to leave things alone unless you just want to help the Economy.
01-30-2017, 04:04 PM | #15 |
Some folks like their car to be simple, as it came from the factory, others like it gussied up. I remember seeing a 29 roadster at the New England Model A Meet in 1971 that had every conceivable accessory added to the car. The owner thought it was great, and it was his car, so his choice. My father looked at the car and said "There is a good example of guilding the lilly".
To each his own. |
01-30-2017, 04:18 PM | #16 |
On our '29 Town Sedan, I reduced the door check strap by one notch; the result being that instead of being able to open the front doors to a 90 degree angle, it has been reduced to maybe a 75 or 80 degree angle, but still more than adequate for ingress and egress. Hope this helps. I've always been one for symmetry, so if I were to consider side mounts, I personally would probably go with two rather than one, but as everyone says, it's your call. I don't think that you can go wrong either way. Best of luck to you in your decision.
Dick |
01-30-2017, 06:20 PM | #17 |
My Phaeton has sidemounts and my '33 pickup has a single passenger side mounted spare. I think they are unique to that era and I like them but I would not go thru all the pain and $$$$$ agony to install from scratch.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
01-31-2017, 01:31 AM | #18 |
I have a Tudor with two side mounts, and I like it.
And some people say : "it's not easy to work on the engine", -> why work on the engine when its running good ? |
01-31-2017, 05:52 PM | #19 |
I've had both side and rear mounts, so here's my opinion. Side mounts do have all the disadvantages others have mentioned. It's your choice as to whether aesthetics outweighs all that. I think side mounts look better on a 30-31 than a 28-29. They look OK on a "two-seater" (sedan, phaeton, etc) but not necessarily better than a rear mount. On a "one-seater" (coupe, roadster, etc), side mounts make the car look out of proportion - too heavy in the front end. If a car has them, I prefer the symmetry of two.
01-31-2017, 09:25 PM | #20 |
Oh, dear! My vehicle looks out of proportion. Must sell! Any takers?
