08-12-2015, 06:47 PM | #1 |
hand crank, not sure if model A
hello- ibought used crank but now not sure if it's for model A-does not lock in crank nut well and slips out easily. the pins are oval-should they be round? i';ve enclosed a picure attachment---i put tape on the pin to better show the shape of the pins. is this model A crank? thanks
08-12-2015, 07:37 PM | #2 |
Re: hand crank, not sure if model A
"Maybe" it fits an OVALMOBILE??
08-12-2015, 07:42 PM | #3 |
How about a picture of the whole crank??
Bob |
08-12-2015, 07:53 PM | #4 |
silly answer from Bill-williamson-----
08-12-2015, 08:12 PM | #5 |
Measurements with the pic's of the whole crank would be a game changer in determining if it is Model A or not. Many originals have alot of wear on the lugs. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
08-13-2015, 02:31 AM | #6 |
08-13-2015, 11:06 AM | #7 |
thank you -will check teeth-also took measurements and found the diam of crank is .75" the pin is 3/16" thickness and is 3/8 " in breadth-------i don't think it was a round pin that has ovalled out.
i guess the last ques i have is: is the crank pin to a model A round, if so this is not a model A crank. thank you Last edited by wbs; 08-13-2015 at 11:07 AM. Reason: incorrect |
08-13-2015, 03:16 PM | #8 |
My original crank pins are oval.
08-13-2015, 04:08 PM | #9 |
My crank pins will always be PERFECT. I'm such a WOOSE, that I CAIN'T crank it. Hope no one gives me a "T" Model Chief sed, "T"= TROUBLE"!!
Bill W.
08-13-2015, 10:51 PM | #10 |
08-14-2015, 12:14 PM | #11 |
Thank you all I am most thankful I did not know that cranks had so many variations. Thank you especially for the list of cranks, I had no idea
08-14-2015, 02:18 PM | #12 |
Mike would you please explain to me what lugs (1) stands for and throw (2) means. Thanks John
08-14-2015, 02:36 PM | #13 |
