01-16-2019, 03:40 PM | #1 |
Yet another old car pic.....
Floating around on FaceBook......
01-17-2019, 01:41 PM | #2 |
Re: Yet another old car pic.....
Cool pic thanks....that's my car
01-17-2019, 03:14 PM | #3 |
I remember when Chief tore down his drive on ramp & had the Hydraulic Lift installed!! The FIRST in town. We also had the FIRST, Fast Battery Charger, in town along with the only 4 way AMBER flashing signal light.!!! It was a Conoco Fillin' Station, next to the Hardware Store & close to the BEST, GREASY Hamburgers & Fried Okra & Onions!!!
Bill W.
01-17-2019, 07:12 PM | #4 |
Is the Model A in the photo being lifted by the front axle and ????
Bob from Northport Northport, Michigan |
01-17-2019, 07:34 PM | #5 |
Bob - good question. I see some pipes running down the side of the running board, and appear to culminate in a 'box' of some sort opposite the back wheel. I wonder if that box is somehow connected to the rear wheel. Hopefully they weren't putting all of the weight on the rear axle......
01-17-2019, 08:02 PM | #6 |
Sent from my SM-J701M using Tapatalk |
01-17-2019, 08:39 PM | #7 |
They figured out 9 ways to lift them--LOL
Bill W.
01-17-2019, 08:45 PM | #8 |
Nothing wrong lifting by the rear axle. The old Ford was easy to hoist up!
01-17-2019, 08:51 PM | #9 | |
W. Michael |
01-17-2019, 11:51 PM | #10 |
I worked at a gas station in the late 50s and 60s(in Huntington NY) that had one of those rail lifts. It was very stable. There were 4 pcs that hooked onto the rails and slid to whatever position you needed, they had a rod about 24" long so you could adjust them easily. There was a U shaped cup that the front and rear axle slid into, once the weight of the vehicle was on it , it did not move. When I moved down to Virginia in 1975 a local repair shop(Reed's garage) had the very same lift and hook-up, it was like being in a time warp. The owner continued to use the lift with slight modifications for newer cars, until the shop changed hands in 1999. It was replaced with a modern lift.
01-18-2019, 10:45 AM | #11 |
W. Micheal - I see what you mean... Thanks!
01-19-2019, 09:53 AM | #12 |
Fender skirts anyone?
01-19-2019, 10:01 AM | #13 |
Skirts are for women not cars!
Bob-A |
