Old 01-07-2021, 09:29 AM   #1
Tatertot
Default Rear axle shaft loose, banjo 38
I have a 38’ PU and wasn’t sure on thoughts to where to start with fixing this- the right rear axle shaft has 1/4” of free play. Looking at the manuals I’m thinking I need a new gear race and can get to it by removing the backing plate- Thanks
Tatertot is offline   Reply With Quote
Old 01-07-2021, 09:37 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Rear axle shaft loose, banjo 38
With the drum ON and tightened is there any movement??
I believe what movement you have now is normal as there's nothing supporting the axle withe the drum removed.
Paul in CT
Old 01-07-2021, 10:06 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
The early Ford banjo rear has whats known as floating axles. The tapered end of the axle in your picture requires the drum assembly with roller bearing to be in place for its stability.
Also, the threaded end of the axle in your picture looks like it could be heavily mushroomed.... unless thats just a distortion in the picture.
John
Old 01-07-2021, 10:43 AM   #4
Tatertot
Thank you- I’ll put the hub on and check. I also think it’s just the picture.
Old 01-07-2021, 10:44 AM   #5
Tatertot
Old 01-07-2021, 03:29 PM   #6
JSeery
JSeery's Avatar
When you go to do the final assembly, be sure the tapered part of both the axle and the drum are spotless clean and dry. The nut on the axle torques down to a very high number. As you most like do not has a torque wrench that will read high enough to read it, get it as tight as you can using a cheater bar/pipe on a breakover bar.
Old 01-07-2021, 08:04 PM   #7
Bored&Stroked
Bored&Stroked's Avatar
You need to use about 200 Ft lbs on the big nut on the end of the axle. I know this makes ones rear-end pucker as you're struggling to put that much torque on it . . . but this high torque number is what ensures that the hub-to-axle tapered surfaces can do their job.
The key is NOT what takes the load (or it shouldn't) - it is the tight fitting tapered surfaces that take the load . . . and they only work as they should with the correct torque figures.
Hopefully the tapered ends of your axles are in good shape - inspect them carefully for cracks around the key-way . . . many get damaged from improper installation or abuse over the years. Hopefully the bearing surfaces on your axle bells are good - in many cases they get pitting over the years . . . which is another problem.
Also, torque it once, drive it around a bit (making sure you go around some corners), then come back and re-check the torque values.
Old 08-29-2022, 06:10 PM   #8
mhsprecher
mhsprecher's Avatar
"Hopefully the bearing surfaces on your axle bells are good - in many cases they get pitting over the years . . . which is another problem."
I am redoing the brakes on my 39 sedan and have noticed 1) the end play (side to side) of the rear axle. From what I have seen here on the Barn, that is normal. Whew. 2) one of my bearing surfaces is scored and pitted a bit. From what Vern Tardel says, they are often usable in that condition. His differential books shows a photo that is similar to my situation. The question is when is it too bad to just reassemble and go?
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 08-30-2022, 12:51 AM   #9
deuce lover
deuce lover's Avatar
This thread is a year 1/2 old.I would think the issue is resolved.Why not start a new thread with your question?
deuce lover is offline   Reply With Quote
