Old 08-27-2017, 03:59 PM   #1
JBohannon
Default Coil Wire Resistance
How do I check the high voltage Coil Wire from coil to distributor?
JBohannon is offline   Reply With Quote
Old 08-27-2017, 04:30 PM   #2
H. L. Chauvin
Default Re: Coil Wire Resistance
Get a multi-meter and a coat hanger wire.
Set multi-meter to where it reads Ohms.
Coil wire and coat hanger wire should have about equal Ohms reading on the multi-meter.
GE analog multi-meters, (yellow), with moving arm, are about $10.00 at Wal-Mart.
H. L. Chauvin is offline   Reply With Quote
Old 08-27-2017, 08:00 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If it's real WIRE-WIRE, don't wurry about it!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-27-2017, 08:50 PM   #4
MAG
MAG's Avatar
Standard swing meters (analog) will read 0 ohms when checking the resistance of a wire type coil wire.
If you want to know the actual resistance you will need a Biddle Meter which reads resistance of less than 1 ohm. (micro ohms).
or
Do what Bill says ...dont worry about it.
Biddle Meters are quite expensive.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 08-27-2017, 09:14 PM   #5
webb452
Per Les Andrews Blue troubleshooting book on page 2-5 you should have the following readings:
Measure ohms from (+) terminal to (-) terminal - 1.6 to 1.8 ohms
Measure ohms from (+) terminal to center (high tension) 6.7K to 10K ohms
Measure ohms from (-) terminal to center (high tension) 6.7K to 10K ohms
Measure ohms from each coil terminal (+ & -) to outer metal case of coil - Open Circuit
If any of these readings are wrong you have a defective coil.
Randy
webb452 is offline   Reply With Quote
Old 08-27-2017, 09:26 PM   #6
mike657894
mike657894's Avatar
its a wire you're not looking for resistance. a old style copper stranded plug wire will work. i dont know what is stock and show correct. to check a wire set your meter to continuity. with you meter set to ohm 0 is a show of continuity.
mike657894 is offline   Reply With Quote
Old 08-28-2017, 11:35 AM   #7
100IH
Stranded metal (copper) wire is original. Resistance leads with the carbon impregnated thread are not recommended.
100IH is offline   Reply With Quote
Old 08-28-2017, 12:08 PM   #8
JBohannon
The reason I ask I think I may have bought a new style wire a year or so ago. When I check for continuity I have none or almost zero ? That is not right is it ?
Old 08-28-2017, 12:37 PM   #9
MAG
MAG's Avatar
No, that is not the proper reading for a coil wire made with copper.
Probably correct for a carbon filled coil wire, depending on the meter scale used,
Old 08-28-2017, 12:51 PM   #10
100IH
Regardless, just look for metalic wire in the end. Also thin cupped shaped ends should be soldered to the wire. Most auto parts stores might not have old style "secondary wire" because resistance wire began a faze out when car radios became popular, hence: "radio resistance wire". The term wire is used loosely as new stuff has no wire in it.
Old 08-28-2017, 07:47 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Just buy the correct wire from A&L, Bert's, Bratton's, or Snyder's.
There is likely other small parts you need if you look through their catalogs.
Old 08-29-2017, 01:18 AM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
See post 6. O is the same as touching the two leads together.
Old 08-30-2017, 03:16 PM   #13
Smog Tech
Smog Tech's Avatar
I was told by Pertronix to use resistance spark plug wire with their ignition system. I would also use it if I had a CB radio.
Smog Tech is offline   Reply With Quote
