11-18-2016, 09:34 PM | #1 |
Front Spring Perch Removal
I'm entirely rebuilding my front axle and now I've gotten to the point where I need to remove the front spring perches. One came out no problem but the other one won't budge. It looks like someone has been at this before and the threads are slightly mushroomed. I've been soaking it with PB blaster and have applied heat from a propane torch but nothing seems to be doing anything. Any suggestions and is there any hope in saving the slightly mushroomed threads?
11-18-2016, 11:15 PM | #2 |
Re: Front Spring Perch Removal
try and get the nut back on and make it flush with the end of the perch thread. I would soak it very good with Kroil penetrant, or Gibbs.. Sometimes they are difficult to remove. I recently had one that was a challenge and managed to save everything. It took quite a bit of soaking, and I applied heat to the area around the axle where the purch is several times. It finally came. I use a large brass hammer so it doesn't damage the threads so much. There is a special press type puller made by snap on ( you must have the correct adapter type) that can be used as well if obtainable.
Soak a lot, heat if need be.. and keep at it systematically. It will come out. Inspect the axle and wishbone well for straightness on both once removed. Best wishes for removal! Larry Shepard |
11-18-2016, 11:33 PM | #3 | |
11-19-2016, 01:14 AM | #4 |
You guys can think so but honestly you do what you have to do to get it out... and I've never had a problem with an axle breaking (LOL)in two or even bending because of it. Many things get overthought....
Of course you can use a press if they have one but have to be careful as well. Ray, have you ever removed a difficult one? Larry |
11-19-2016, 01:20 AM | #5 |
King pin would just not come out.
11-19-2016, 01:22 AM | #6 |
Larry |
11-19-2016, 01:32 AM | #7 |
That was what I was told,
11-19-2016, 02:59 AM | #8 |
11-19-2016, 10:57 AM | #9 | |
11-19-2016, 01:01 PM | #10 |
Ever wonder how they make a dropped axle.
11-19-2016, 04:41 PM | #11 | |
I built this tool because I had a lot of front axles to disassemble and I didn't want to use heat. Worked good! Bill |
11-19-2016, 05:41 PM | #12 |
A guy I know brought his axle and wishbone assemble over to me and I used my 5 ton hydraulic press and had to add a little heat to get them out.
Cant remember who made this but I might make one next time. Worth a try. |
11-19-2016, 06:21 PM | #13 |
Thats a cool looking tool!! Tools are good
DJ S this might be a good time to try the suck candle wax up in axle bushing, someone posted a u-tube link last week. Let us know how,when you get it apart :-) |
11-19-2016, 09:18 PM | #14 |
Yep, that is a great looking tool. It's always better to pull than to push a stuck part, if possible, and that looks like the perfect tool for the job.
11-19-2016, 09:26 PM | #15 |
If any body can make one, that would be you Tom. And yes, pulling would be much better than pushing. I think I seen this on the hamb some time ago. Hope who ever made it doesn't mind if I borrowed the picture.
