Old 03-16-2021, 01:52 PM   #1
sphooch
sphooch's Avatar
Unhappy brake return spring ??
Hi guys, brake pedal doesn't want want to return all the way. So i bought a return spring from brattons. I know its after market but i figured i'd give it a try. it comes with a spring and a metal hook but no instructions on how its installed, any one ever put one in there car. its a 31 roadster. I tried to post a pic. of what i have but no luck doing that either. thanks THE HOOCH
sphooch is offline   Reply With Quote
Old 03-16-2021, 02:12 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: brake return spring ??
I don't have it on my car, it returns fine, but have seen one that hooks over the pedal arm and hangs down, with spring connected to motor mount hole
What condition are your anti rattle springs?
Old 03-16-2021, 02:29 PM   #3
jak
the heavy metal bracket wraps around the brake pedal, and the coil spring hooks to that bracket on one end and the motor mount on the other.
click here to see a diagram
https://www.brattons.com/files/index...id/1497547036/
jak is offline   Reply With Quote
Old 03-16-2021, 04:20 PM   #4
WHN
I have used for years. Works great. Our 29 has a completely rebuilt brake system. Everything new or rebuilt including all rods and springs. Still use the return spring. Paddle pops right back, hits the floor board.
Old 03-16-2021, 06:27 PM   #5
Gene F
Gene F's Avatar
I had one at one time. It was fine. Just didn't need it, so once when I was working on the car I did not put it back on.
Old 03-16-2021, 06:31 PM   #6
gdmn852
gdmn852's Avatar
Hello, I have bought the return spring you are talking about but have yet to try it out , just bought car late fall.Has hydraulic brakes that seem to be hanging up.Good to know it works .
gdmn852 is offline   Reply With Quote
Old 03-17-2021, 06:22 AM   #7
bob from red oak
bob from red oak's Avatar
When I bought my A the brake peddle would not fully return and the brake light stayed on. I installed the return spring from Brattons and and peddle returns all the way and brake light goes off.
bob from red oak is offline   Reply With Quote
Old 03-17-2021, 01:08 PM   #8
twilder
twilder's Avatar
I used one also. Returned the pedal great, but I found that actually fixing the problem worked great as well. Replaced bushings in brake and clutch pedals, new brake rods and anti-rattlers. inexpensive fixes that eliminated the need for the return spring
twilder is offline   Reply With Quote
Old 03-17-2021, 04:37 PM   #9
The Master Cylinder
The Master Cylinder's Avatar
Imagine that! Fixing the problem actually fixing the problem. Without the need of additional parts (Bandaids?). Good job, twilder!
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-17-2021, 09:59 PM   #10
daren007
By a spring from your hardware store and fabricate your own brackets
daren007 is offline   Reply With Quote
Old 03-18-2021, 05:20 PM   #11
Slowmotoring
Slowmotoring's Avatar
But if we fix it the “correct way”. What will we “fix” next weekend?
Good things take time
Slowmotoring is offline   Reply With Quote
