Old 04-23-2011, 02:05 PM   #1
d_Seymour
Default 29 roadster glass bumper local plus Rocky type brake drums
When sand blasting the panel there were three holes grouped very close together for the little rubber bumpers used to support the glass when top is down. Can someone provide the distance between these bumpers from front to back of car. The two nearest the deck lid are original so width is set but had to weld three front holes. A mess hidden by body mud.
Next question came across a pair of rocky front brake drums cast type. Currently my roadster front brake drums are original the steel type. Should I buy these to replace the steel type. They are complete bearing etc. Will these improve brake effort stopping power? Cheaper than Walmart.
d_Seymour is offline   Reply With Quote
Old 04-23-2011, 02:18 PM   #2
Charlie Stephens
Default Re: 29 roadster glass bumper local plus Rocky type brake drums
Measure them before you buy. 11.060 max if they are installed on hubs and have been turned (11.060 is MAX and you cannot turn them again). If they measure 12 inches they are '32 and up drums.
Charlie Stephens
Old 04-23-2011, 02:24 PM   #3
d_Seymour
Charlie if they measure within specification would it be worth the effort to change for stopping power are the rocky type better.
Old 04-23-2011, 04:06 PM   #4
Charlie Stephens
I hope someone responds to this that has used both. I have had pressed steel drums with reinforcing bands for the last 20 years (I don't drive much) and no experience to compare the two. The rocky mountain type is definitely better but if it is worth the change I cannot say. A lot would depend on what the two drums are like. Again, be sure they are not the later 12 inch drums.
Charlie Stephens
Old 04-23-2011, 04:15 PM   #5
LukeDahlinger
From what I remember there should be 4 holes for the rubber pieces on the upper panel. I don't have any measurements handy, but I'm sure someone will come along that does.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 04-23-2011, 06:14 PM   #6
d_Seymour
Luke let me clarify there were three holes grouped so close together they almost overlapped one other, both holes to the front of vehicle so close I just welded them all because I could not decide what were original holes for a total of six three per side. Strange
Old 04-24-2011, 01:20 PM   #7
d_Seymour
/anyone know the pattern dimension for the glass bumpers
Old 04-24-2011, 01:37 PM   #8
Dan/Kzo
Dan/Kzo's Avatar
The rocky mountain drums would be a good upgrade. I have both types on different vehicles.
Dan/Kzo is offline   Reply With Quote
Old 04-25-2011, 02:36 PM   #9
d_Seymour
Yes the brake drums were 32 measured 12 inches he did know there was difference. I have aset of 32 brakes. Does any one have a 29 roadster with glass bumpers on the deck lid panel. need the spacing front to back of vehicle. Please help so i can drill new holes before finish the panel.
Old 04-25-2011, 02:46 PM   #10
Jim Parker Toronto
Jim Parker Toronto's Avatar
You could always wait to drill the holes, until after the paint job, and line up the bumpers with your window glass, that way you are assured of a good fit. If the installed window is off a little, you still want the bumpers to work. I also found that there is two types od bumpers available when I did mine, the ones with studs and nuts, and the solid rubber kind that just pull through the hole, and they lock in place. Jim
Jim Parker Toronto is offline   Reply With Quote
Old 04-25-2011, 03:11 PM   #11
okieford
okieford's Avatar
I have a 29 roadster with the rubber bumpers installed for the glass in the top. I am leaving the office before long and will measure the locations. It will be late this evening before I can post the results.
okieford is offline   Reply With Quote
Old 04-25-2011, 03:17 PM   #12
Jim Parker Toronto
If you have the backing plates, and the shoes, you can install the 32 drums on a Model A. The rest if the parts, except the actuater pins, are the same I think...
Old 04-25-2011, 09:38 PM   #13
okieford
okieford's Avatar
I measured the rubber bumpers from the edge of the panel to the center of the bumper. I didn't want to pry the bumpers from the panel. By the edge of the panel I mean from the edge of the opening for the trunk or rumble seat lid. I did not include the water channel. The forward bumpers are 7 inches from the edge. The rear bumpers are 2 3/8 from the edge. The bumpers are 14 inches left to right and of course they are centered.
Old 04-26-2011, 10:11 AM   #14
d_Seymour
Okieford you are a gentleman and a scholar , much appreciated can now move forward with confidence drill those missing holes final fill and finish of panel for paint.
