07-22-2022, 02:20 AM | #161 |
Re: Engine temp rises when I get to cruise speed
Shoebox
I removed the CCI fan/shroud last night and I'm installing a Flex-a-lite puller fan this this weekend. They have a new series that's supposed to put out 3000 cfm. if this don't work, it's the radiator . I spoke to Lee from Brassworks again yesterday and still he accepts no responsibility so I'm on my own here. Thanks for asking! Joe |
07-22-2022, 06:48 AM | #162 |
What’s the price of a reputation? $1,000, $1500? $10,000? It’s incalculable the cost in lost business as Brassworks continues to refuse to step up and end this absurdity. Even if Lee stepped forward today, he has still lost tens of thousands of dollars in future business. It just makes good business sense for Brassworks to stop the bleeding right now from his self inflicted wounds.
Richard |
07-22-2022, 10:01 AM | #163 | |
07-22-2022, 10:01 AM | #164 | |
07-22-2022, 12:03 PM | #165 |
Can you post a pic of the new puller fan as I thought there was no room for one. If that fan can pull 3000 CFM, then I wound hazard to guess that there should be no issue at cruise or idle. Would be interesting to know what the fan pulls at idle.
07-22-2022, 12:26 PM | #166 | |
He never brought up core size when we put the order together. I relied on him to tell me what I needed and he failed as far as I'm concerned. I didn't want to mention this, but I will now. I installed his radiator and drove the car twice for less than 10 total miles total and I noticed the top mount where the firewall rods are tied in, started to tear away from the top tank. I sent him numerous emails over a two month period and heard NOTHING from him. I pulled the radiator and brought it to get repaired by a well known shop near me which cost $255!!! When I mentioned that to him yesterday he said " that shouldn't have happened" and that was the end of the conversation. I already contacted CAR here in jersey for a radiator because this dope WILL NOT take responsibility for "assuming I didn't have enough room because I said I had no room for a puller. Professional my a$$ I'm waiting for a puller fan to come. It should be here tomorrow Hopefully I'll have time to install it and take it for a test run. Thanks Joe |
07-22-2022, 12:30 PM | #167 |
07-22-2022, 12:31 PM | #168 |
07-22-2022, 12:43 PM | #169 | |
I would've gone with the Spal, but it was only 2024 cfm. Even if the Flex-a-lite gives me 2200 cfm, it's still more than the Spal. I really never knew I could fit a puller of that size in there. Last night I tried a Spal pusher and to my surprise it fit! I wish I tried that before I spent the $420 on the CCI fan/shroud!!! Let's hope for the best. Thanks Joe |
07-22-2022, 02:36 PM | #170 |
Beware of aftermarket fans and shrouds. I bought a '51 Ford that had a aftermarket fan and shroud plus air. The air didn't work. I removed the air and left the fan and shroud thinking they would help the cooling. Still ran hot at idle or at speed! Put a piece of paper in front of rad. at idle and it fell off! Took off the aftermarket fan and shroud and guess what, no more overheat!
The fan I used was a stock four blade fan and it will hold a piece of paper tight to the rad. These are just my results, yours may very. |
07-22-2022, 04:14 PM | #171 | |
Thanks for the input! Joe |
07-22-2022, 04:45 PM | #172 |
Joe what lousy a way to spend your summer. Experimenting and spending more money trying to fix a problem that's caused by a very poor quality radiator. What you just wrote about the support rod mount needing repair on a new radiator after only 10 miles that repair expense should have been covered by brassworks.
I can tell you when I experienced an issue with the radiator I received from CAR after many months of use. All they asked I do is have it fixed locally and submit the bill to them. Some company's are interested in service and future sales its obvious brassworks in not one of them. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-22-2022, 05:04 PM | #173 |
Still not listening. Still not understanding.
High speed overheating is rarely a fan problem and more frequently trapped air which in your case is causing heat soak. Twice I suggested you remove the shroud, mount the puller fan you have and get numbers. If it improves and you seek more cooling, position the SPAL fan pusher higher and the Cooling components puller fan lower to prevent the heat soak at 50-40 mph (and get more numbers). If you still want more cooling swap the Cooing components for a higher cfm SPAL fan. We keep talking through this and you told me you would do this twice and you did not do it. You called cooling components and they told you to cut holes in the shroud to free air. You instead fixate on two fans and went on this forum to rant. You also want to buying fans with advertised cfms that likely come from a controlled lab environment and not the real world. Something we discussed and I thought you understood. I can't help you if you won't listen and when you talk sh*t on this forum about me it makes me not want to. Apologies if this candor offends the delicate sensibilities of the forum. |
07-22-2022, 05:12 PM | #174 | |
07-22-2022, 05:18 PM | #175 | |
07-22-2022, 05:28 PM | #176 | |
The cooling components fan blades are fixed to a ring and that ring is inside the shroud. The entire fan shroud area must be pulled through a ~7/8' gap to get out. Last edited by The Brassworks; 07-22-2022 at 06:32 PM. |
07-22-2022, 05:34 PM | #177 | |
We also had an extensive conversation yesterday about fans and stated/advertised cfms and you elected to go with a flex-a-lite. You went your own way again. I seriously cannot believe you. |
07-22-2022, 05:43 PM | #178 | |
We have been trying to help Joe but Joe won't help himself. We have tried from the start but Joe has not listened and won't listen. He has been on this forum ever for a purpose other than getting his engine temperature down 10 degrees. Perhaps you do not see it but I do. Pompously yours, Lee |
07-22-2022, 05:57 PM | #179 | |
Can you hear the silence
07-22-2022, 06:26 PM | #180 |
