10-09-2020, 10:37 AM | #1 |
headliner grabber/door tins....an idea
I wonder if this would work with a little modifying? Just cut off the rounded part and flatten out all the rows of teeth except the first one. It's aluminum, so with a little hammer and dolly work one might be able to bend it if a curve is needed. In case the link doesn't work, it's a carpet grabber or transition strip used in buildings where a carpeted floor meets a vinyl or tiled floor.
Anyway, here's the Home depot link: https://www.homedepot.com/p/TrafficM...MF12/308371112 These should be available at any hardware store. I've never tried this.So it may or may not work. |
10-09-2020, 10:40 AM | #2 |
Re: headliner grabber/door tins....an idea
That type (alloy) of aluminum is not easy to work, it is more likely to crack/break than move when worked.
10-09-2020, 11:00 AM | #3 |
10-09-2020, 01:58 PM | #4 |
https://www.amazon.com/House2Home-Up.../dp/B07SJZXCDZ
This can be used; there was recently a thread either on here or the hamb with detailed pictures of using this in place of missing original strips. There is also a thread showing how to form some light galvanized sheet metal (duct tin) to act as a retainer strip. |
10-09-2020, 04:31 PM | #5 |
Thanks Rich.I'm aware of the original thread and thought a transition strip would be a little sturdier. My coupe is done and the strips were in good shape.I was just offering a suggestion in hopes of helping others.
10-09-2020, 07:53 PM | #6 |
Prolly enough to do 10 cars! |
10-11-2020, 06:56 PM | #7 |
Hi there. I am going to try to install a headliner on my new to me 1942 ford super deluxe. The suggestions I have read here will help. Old headliner was gone so not sure how they treated the rear window flange. Does anybody know what might work best?
10-11-2020, 07:32 PM | #8 |
The headliner folds over and glues to the rear window flange and the rubber gasket holds it in place.
