Old 04-25-2019, 11:23 AM   #1
Cool Hand Lurker
Cool Hand Lurker's Avatar
Default 12 Volt Alternator Wiring idea
My 47 Coupe was already converted to 12V with a GM 10SI alternator when I bought it. The old voltage regulator was gone and the output wire from the alternator ran directly over to the solenoid. I am restoring the wire harness to stock so I decided to use the original generator-to-voltage regulator harness. I put in a fake voltage regulator that had no relays inside, just a couple of jumper wires. I ran the alternator wires to the fake voltage regulator terminals as it was originally. That kept the wiring really simple and looking original.
Here is how I did it:
I removed the three regulator relays but left the insulating spacers in place and connected the lower outside terminal bars to the inside of the housing with machine screws. Inside, I connected a #8 wire from the ALT bar screw to the BAT bar screw and a #12 wire from the ALT bar screw to the FIELD bar screw.
The wires coming from the alternator now go to the fake regulator ALT & FIELD terminals and the wire from BAT terminal goes to the battery through the original harness hookup.
File Type: jpg 6 Ford 1947 engine-alternator wiring.jpg (38.3 KB, 44 views)
Cool Hand Lurker is offline   Reply With Quote
Old 04-25-2019, 02:29 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 12 Volt Alternator Wiring idea
Good idea with excellent visuals.
Did the same thing over 20 years ago but with a 1 wire GM.
A single buss bar from A to B.
The extra space in the Reg. is used to hide a push button switch for an under-hood light.
Old 04-25-2019, 05:11 PM   #3
JSeery
JSeery's Avatar
Now that is an interesting add-on!
Old 04-25-2019, 07:53 PM   #4
Cool Hand Lurker
"The extra space in the Reg. is used to hide a push button switch for an under-hood light."
Why do you need a switch for an under-the-hood light? Wire the light to be always on, even when the hood is down. You know, like in a refrigerator where the light stays on after you close the door.....
Old 04-25-2019, 08:06 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Wonder how many actually climbed into a refrigerator to see.
The switch is mainly to shut the light off during car shows etc. as it is equipped with a mercury switch that turns it on with the hood up.
Old 04-25-2019, 11:58 PM   #6
Scotty's 52 F3
Scotty's 52 F3's Avatar
Cool idea. Pun intended. Thanks for posting the details.
Scotty's 52 F3 is offline   Reply With Quote
Old 04-26-2019, 10:37 AM   #7
Cool Hand Lurker
Thanks for the comments. My next project will be to fit an alternator into a stock generator housing so that will look original too. That alternator just doesn't look "FORD".
Old 04-26-2019, 09:49 PM   #8
4dFord/SC
4dFord/SC's Avatar
Cooling might be a problem with the stock housing. I think that's why Ed Whitney uses his own housing for his conversions.
4dFord/SC is offline   Reply With Quote
Old 04-26-2019, 10:36 PM   #9
Scotty's 52 F3
I thought about it but, just kept the generator. The only electrical load I've added is A/C.
