Old 08-24-2014, 08:27 PM   #41
Bassman/NZ
Bassman/NZ's Avatar
Default Re: changing plugs every 100 miles!!
Originally Posted by rodderbilly View Post
brass float and fuel pump changed.....i put 0.69 power valves and 41 jets....now the engine runs very well!!
Excellent! Problem solved. Are you still running the hotter plugs? Do they make any difference?
Bassman/NZ is offline   Reply With Quote
Old 08-25-2014, 12:18 PM   #42
rodderbilly
rodderbilly's Avatar
yes i'm running the b4l ngk.....engine goes around 180 deg......now accelerate very fast and haule ass!....i think all the changes make that difference....sure the hotter plugs help the engine ....
rodderbilly is offline   Reply With Quote
Old 08-25-2014, 12:49 PM   #43
supereal
supereal's Avatar
If you are running an 8BA with a Stromberg carb (97) and a distributor that needs vacuum, such as the stock 8BA, it is likely that there is no timing advance. That would certainly explain your problems. The 8BA requires the correct carb so the vacuum can be drawn above the throttle plates.
supereal is offline   Reply With Quote
