Old 12-22-2015, 10:17 PM   #1
d_Seymour
Default 1959 galaxie body mounts & air intake panels
Happy Holidays
At this time working on replacing original body mounts . According to the ford manual the rubber style bushings must be tighten every 9000 miles. So are there urethane bushings available in the market place.
Next
The air intake-panels behind the grill on my galaxie were cobbled not original . Purchased body manual turned out no show for front panels. Could some one send pictures or panel layouts. Or give me a heads up.
d_Seymour is offline   Reply With Quote
Old 12-25-2015, 08:57 AM   #2
rick55
rick55's Avatar
Default Re: 1959 galaxie body mounts & air intake panels
Hopefully this is what you need...
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 12-25-2015, 12:24 PM   #3
d_Seymour
Happy Holiday Rick
Appreciate the feedback a most helpful attachment. So there are housing the tubs attach to. But how do the housing attach to the front end is there a panel missing. Or do the housing attach directly to the radiator support.
Are there replacements housing available. My Galaxie has cut up bad tubes that were supported by furnace duct works. Bad setup.
Have a wonderful holiday
Old 12-27-2015, 10:58 PM   #4
Unshined2
The tube (#01902) bolts to the housing (#8014), which in turn bolts to the bottom of the front fender below the headlights....if i remember correctly....
Unshined2 is offline   Reply With Quote
Old 12-28-2015, 08:51 AM   #5
okiedokie
okiedokie's Avatar
" According to the ford manual the rubber style bushings must be tighten every 9000 miles. So are there urethane bushings available in the market "
Hope you get an answer to this question, I would love to know.
okiedokie is offline   Reply With Quote
Old 12-30-2015, 10:15 AM   #6
bobss396
bobss396's Avatar
That's about it. And if you take out ALL of the bolts around the intake opening.. the entire tube will drop onto the floor. So prop it up or always have one bolt through everything.
Someone on eBay sells the body bushings, Vintage Ford Parts I believe.
bobss396 is offline   Reply With Quote
