Old 06-24-2015, 05:29 AM   #1
d_Seymour
Default 32 front axle assembly
Good Day,
have a question regarding using a 32 front axles assembly on a model a.
Would I need to replace the 32 King pins with model A king pins in order to stay with the model A brake actuator rods setup.The 32 actuators angle in towards the center of the car.
d_Seymour is offline   Reply With Quote
Old 06-24-2015, 06:24 AM   #2
kelley's restoration
kelley's restoration's Avatar
Default Re: 32 front axle assembly
you'll have to replace both the king pins and actuatorsalso need a spacer for the wishbone
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 06-24-2015, 07:00 AM   #3
26Tguy
26Tguy's Avatar
EDIT : incorrect info removed so as not to confuse anyone. Sorry
26Tguy is offline   Reply With Quote
Old 06-24-2015, 07:22 AM   #4
1928Fordman
1928Fordman's Avatar
32 Ford axles are 2" wide at the spring perch boss and model a's are 2 1/4".
1928Fordman is offline   Reply With Quote
Old 06-24-2015, 07:05 PM   #5
d_Seymour
Thanks Kelley
I have model a components, Should the perch pins also be changed. I can remember a tech Post with great pc's but I can not find it. The post was really detailed, as I recall it was a couple of years ago.
Old 06-24-2015, 07:37 PM   #6
Bob C
Yes you need 32-34 spring perch, I got new ones from Bob Drake
hope they hold up.
Check this thread. http://www.fordbarn.com/forum/showth...light=lowering
Bob
Old 06-25-2015, 09:20 AM   #7
COOTER
I just attempted to do this swap but using Model A spindles. Before full lock, the tie rod hits the crossmember...even if I drop the steering arms. Assuming you are using '32 spindles, let me know if it works out for you.
COOTER is offline   Reply With Quote
