Old 03-22-2021, 07:25 AM   #1
jwmckenzie
Default Victoria Body Number 190A 21292
My Nephew just picked up a Victoria, it's a steel back, flat firewall and has a Murray body tag. Here is a pic of the body tag.
We are trying to date this body. The frame and motor are likely not part of the original configuration of this car, so no help there.
Our research to-date would indicate this body tag should be associated with a leather back. We see no evidence of the firewall being changed, or the Body tag being removed and reinstalled.
Any help would be appreciated.
jwmckenzie is offline   Reply With Quote
Old 03-22-2021, 09:32 AM   #2
Steve Plucker
Default Re: Victoria Body Number 190A 21292
If production numbers were associated with the Body Tag number, then your "190A 21292"
would of been built in early April 1931 along with 7139 other bodies.
Pluck
Old 03-22-2021, 03:50 PM   #3
Bob Bidonde
Bob Bidonde's Avatar
I am not so certain that 190A21292 is a Steel-back. Please post some pictures of the car.
Bob Bidonde
Old 03-22-2021, 04:28 PM   #4
jwmckenzie
Here is the rear quarter panel.
The firewall has not been changed out of the cowl. I suppose it is possible a different rear has been put on a cowl with doors, but the top looks like it is attached with original nails to the header.
Old 03-23-2021, 09:59 AM   #5
Bob Bidonde
I need to see the rear window and roof opening to be certain. The reason I am challenging the body style is that 21292 falls within the tail end of Leather-backs in the record of survivors.
Also, look at the rivets holding the 190A body tag on, and compare them to the rivets holding the patent data tag on. It appears the 190A tag may be an original from another Victoria.
Bob Bidonde
Old 03-23-2021, 03:20 PM   #6
jwmckenzie
Originally Posted by Bob Bidonde View Post
[SIZE=3]I need to see the rear window and rood opening to be certain.
I will see if I can get some pics sent. Please clarify "rood opening".
We are coming to the conclusion this body tag is not associated with the back of the car.
Old 03-24-2021, 08:29 AM   #7
Bob Bidonde
It should be the roof opening.
Bob Bidonde
Old 03-25-2021, 09:22 AM   #8
jwmckenzie
Here are some more pics.
Old 03-26-2021, 08:30 AM   #9
Bob Bidonde
The Victoria in the photos is a Steel-back, but the body number 190A21292 is unusually low, and way down into the range of Leather-backs. The estimated assembly date of 21292 is December 1930. The oldest Steel-back in the record that has a body number consistent with the start of Steel-backs is 28359 that dates to an early March 1931 assembly date. I suspect that the body number tag on the car in the pictures came from another Victoria that was a Leather-back.
If you would like it, I can reserve a body number for 21292 that fits into Steel-back range. The 21292 tag can be replaced, and that tag sold to an owner of a Leather-back in need of it.
Bob Bidonde
Old 03-26-2021, 09:55 AM   #10
Steve Plucker
Bob,
Please explain your "dating" theory?
I am interested as many others might be.
Thanks.
Pluck
Old 03-27-2021, 08:11 AM   #11
Bob Bidonde
The basis of my dating theory is the record of survivors I maintain for the International Victoria Association. There are 595 surviving Victorias in that record, and the changeover from Leather-back to Steel-back on Ford vehicle assembly lines is noticeable.
Bob Bidonde
Old 03-27-2021, 10:14 AM   #12
Steve Plucker
Bob,
I understand your "dating theory" completley...I guess there are a few ways to look at it.
So if your theory is correct, then by the end of December 1930, there were 4,715 Leatherback Victorias that had been sold, and or assembled by the Murray Corporation, that were distributed to the Ford Assembly plants according to the Ford Motor Company's YEARLY 1930 Assembly Record Type document.
If this "estimated" assembly date of 190A-21292 is December 1930, and if the Murrary Corporation was adding tags in consucutive order, then this would mean that there were 16,577 bodies of the Leather Back Victoria's in float at the Murray Corporation headquarters and/or at the varrious assembly plants, ready to be assembled onto a chassis.
Pluck
Old 03-28-2021, 09:09 AM   #13
Bob Bidonde
Hi Steve. My conjecture is built upon observation of the list of 598 survivors, and I realize that it differs from your research that is based on company documents. My best guess on the basis of the list is that, the changeover to the Steel-back at Murray was between body numbers 190A28202 & 190A28269. 190A28269 is the first Steel-back in the list.
The changeover in the list:
190A27924 LB
190A28154 LB
190A28202 LB
190A28269 SB
190A28359 SB
190A28385 SB
Bob Bidonde
Old 03-30-2021, 09:12 AM   #14
jwmckenzie
Thanks, I will pass this information on to my Nephew.
Thread Tools
Display Modes
