Old 01-08-2021, 09:22 PM   #1
smurph
smurph's Avatar
Default Battery charger
Anyone have a recommendation for a good quality 6 volt battery charger?
And a good quality trickle charger?
Thanks in advance
Smurph
smurph is offline   Reply With Quote
Old 01-08-2021, 09:28 PM   #2
AlexLohmann1
AlexLohmann1's Avatar
Default Re: Battery charger
I have a rolling battery charger made by Schumacher and a trickle charger also made by Schumacher. I have some battery tender trickle chargers and a prologix 6v/12v portable one. As you can see, you can never have enough battery chargers. Haha!
Sent from my SM-G975U using Tapatalk
AlexLohmann1 is offline   Reply With Quote
Old 01-08-2021, 09:30 PM   #3
eagle
eagle's Avatar
This one is both: https://www.amazon.com/Schumacher-SC...ts_id=15707061
Schumacher makes a good charger.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 01-09-2021, 02:10 AM   #4
Ruth
Never had a problem with any of the Battery Tender products. The have numerous chargers and maintainers, both 6v and 12v.
I have tried the other brand with varying success.
Ruth
Old 01-09-2021, 08:05 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
Schumacher makes excellent battery chargers. Here's one:
Schumacher SP1356 Charger / Maintainer 6V & 12V
Bob Bidonde
Old 01-09-2021, 08:43 AM   #6
shew01
shew01's Avatar
This is what I use. The previous owner let it go with the purchase of my 6 volt Model A. I purchased a second one like it for my 12 volt Mustang so I can maintain both batteries at the same time. (There is a 6v/12v switch on it.) I especially like the price, about $20.
https://www.amazon.com/gp/aw/d/B0051...b_b_asin_title
shew01 is offline   Reply With Quote
Old 01-09-2021, 09:43 AM   #7
ModelAMike1930
ModelAMike1930's Avatar
We use Deltran Battery Tenders on 4 of the 6 cars in my family. I have been using them for many years with no problems.
ModelAMike1930 is offline   Reply With Quote
Old 01-09-2021, 10:45 AM   #8
mhsprecher
mhsprecher's Avatar
I have a couple of rolling battery chargers. I bought two from Speedway. One gave up the ghost, so I bought a Schumacher. I think it is hard to buy a good quality charger. Just my experience.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 01-09-2021, 10:49 AM   #9
denis4x4
denis4x4's Avatar
I have remote battery posts on both of my A's to make it east to use a trickle charge or jump start some poor soul. 12v of course. They're available from Speedway or NAPA
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-09-2021, 11:12 AM   #10
katy
katy's Avatar
I have a "Genius" 6/12 volt, 4 amp charger/maintainer that works great.
There's lots of makes and models out there, check out the reviews and take your pick.
Old 01-09-2021, 01:18 PM   #11
eagle
eagle's Avatar
One thing to remember, slow or trickle chargers are much better for the battery than higher rate chargers. If one of my vehicle batteries gets accidentally discharged, if its not an emergency to get it on the road right away, I always use a trickle charger on the battery, leave it on for a couple days if possible. A lead acid battery likes a long slow charge to get it back in shape after the trauma of a complete discharge. Even if you jump start a modern car and drive it a while, when it gets home for the night put a trickle charger on it over night to bring the battery back up to snuff. Most of the automatic chargers will go into a trickle or maintenance mode after a few hours of charging, that doesn't mean the battery is "done". Leave it to top off. Longer the better, within reason. I know someone that parks his modern car for the winter and just uses his pickup. He doesn't disconnect the battery or charge it at all in the winter. In the spring of course it usually won't start so he jumps it to get it going. Batteries don't last more than a couple years.
Old 01-09-2021, 02:41 PM   #12
Brubaker
Brubaker's Avatar
Recently purchased a Genius G3500. No complaints.
Brubaker is offline   Reply With Quote
Old 01-09-2021, 02:50 PM   #13
2935ford
2935ford's Avatar
I also have one.
Works great.
2935ford is offline   Reply With Quote
Old 01-09-2021, 02:59 PM   #14
woofa.express
woofa.express's Avatar
[QUOTE=eagle;1972137]One thing to remember, slow or trickle chargers are much better for the battery than higher rate chargers. If one of my vehicle batteries gets accidentally discharged, if its not an emergency to get it on the road right away, I
etc etc.
That was informative, thankyou Eagle.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 01-09-2021, 06:26 PM   #15
d.
I have used a Harbor Freight 6/12, charger/maintainer for years with good results. It cost $24 on sale.
It reads the current voltage and shows when it is charging, like a thermometer going up.
It shuts off and maintains when the proper voltage is reached.
yes, it is digital and easy to read.
d. is offline   Reply With Quote
Old 01-09-2021, 11:30 PM   #16
midgetracer
midgetracer's Avatar
Battery Tender or NCCO Genius are good tenders. Schumacher last only one to three seasons. I have 10 6V model As that I keep a battery tender on all winter, which is long up here. Schumacher will warranty theirs if in the warranty period, but it takes at least a month when you send it in. I have also had bad luck with Black and Decker(usually last only one season)Some of my Battery Tenders are 15 years old and none have failed.
midgetracer is offline   Reply With Quote
Old 01-09-2021, 11:55 PM   #17
The Master Cylinder
The Master Cylinder's Avatar
I bought a Schumacher when I read a similar thread on Ford Barn a couple of years ago and I thought I would try one, even tho I have always used Deltran battery Tenders in the past with no problems. Glad I only bought one. It only lasted ~6 months. One of the Battery tenders I have had for over ten years. I have 4 Battery tenders now of different sizes.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 01-10-2021, 12:06 AM   #18
Y-Blockhead
Y-Blockhead's Avatar
I remember working at service stations in my youth. Someone would bring a battery in for a charge. We would pop the caps off and proceed to boil the crap out of them for a couple of hours until the customer came back, acid splattered all over the top and the ground. You could always tell where the battery charge 'station' was. All the black cement floor was eaten up and white in that area.
Wiped them off with the red shop rags that turned blue when they came into contact with the battery acid and they were ready to go...
Eagle, Excellent advice on the slow charge. I use a Deltran 750mA Battery Tender Jr.
Old 01-10-2021, 03:06 PM   #19
California Travieso
Send a message via Yahoo to California Travieso
I had the same experience with a Schumacher. I’ve also had a good experience with Deltran Battery Tenders.
I also have a 6V/12V battery charger and maintainer I bought at Sears many years ago. It is still working and I can select the level of amps to charge and use to start my cars if the battery is low or dead.
David Serrano
California Travieso is offline   Reply With Quote
Old 01-10-2021, 04:40 PM   #20
beefheart
I like the battery tender products, I also have a 40 year old Schumacher 6-12 volt charger that still works great!
beefheart is offline   Reply With Quote
