Old 01-18-2020, 04:50 PM   #1
Werner
Werner's Avatar
Default Engine pans
Guten Abend!
Does anyone have mounted these parts and can show me a picture how it looks when they are installed?
Is this a new idea or an addition from the car era back the 30-th?
https://www.brattons.com/eng-splash-...er-coated.html
Thanks!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 01-18-2020, 04:58 PM   #2
aford193031
aford193031's Avatar
Default Re: Engine pans
Ford installed them originally. Many people have removed them over the years. They use two of the oil pan bolts and two bolts to the frame.
aford193031 is offline   Reply With Quote
Old 01-18-2020, 06:18 PM   #3
Mike Peters
Mike Peters's Avatar
Some say that engine splash pans aid in cooling the engine. I really can't say from experience if that is true or not.
Mike Peters is offline   Reply With Quote
Old 01-18-2020, 06:57 PM   #4
Brentwood Bob
Also as a ground path, a ground from frame to engine.
Brentwood Bob is offline   Reply With Quote
Old 01-18-2020, 07:41 PM   #5
denniskliesen
denniskliesen's Avatar
They use 3 bolts to the frame.
denniskliesen is offline   Reply With Quote
Old 01-18-2020, 08:37 PM   #6
whirnot
whirnot's Avatar
Werner,
I feel they are important. They direct air across the exhaust manifold and the block itself, instead of letting it escape out the bottom. They also look good and keep the engine compartment cleaner. And as stated about they also assure an electrical path, Engine to frame.When you put them in place from the bottom, it is very obvious what bolts are used to hold them on.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 01-18-2020, 10:42 PM   #7
dennis lumbert
dennis lumbert's Avatar
Kind of hard to take pictures of but I gave it my best attempt
File Type: jpg 5C0CFFB8-0093-4221-9EF4-143A125FF90C.jpg (72.0 KB, 331 views)
File Type: jpg 04A0D3BE-8529-4345-9465-C11F4B8379F8.jpg (39.6 KB, 324 views)
dennis lumbert is offline   Reply With Quote
Old 01-18-2020, 11:18 PM   #8
gary678*
Very helpful when you don't use an air filter on the carburetor.>
gary678* is offline   Reply With Quote
Old 01-18-2020, 11:40 PM   #9
Conaway2
Conaway2's Avatar
I agree with Whirnot in post #6. I think they help with cooling the engine, but certainly will catch your air-maze filter if it falls off ! Also, they are original equipment, so I have them installed on my car.
Conaway2 is offline   Reply With Quote
Old 01-18-2020, 11:48 PM   #10
alexiskai
alexiskai's Avatar
Werner, take a look also at these older threads on the engine pans. The two most common problems are (1) difficulty with the installation due to the mount points not quite being where they're supposed to be or the holes being too small and (2) vibration at the mount points causing noise as well as wear on the flanges. Various fixes are proposed in the threads for both issues.
https://www.fordbarn.com/forum/showt...7430&showall=1
https://www.fordbarn.com/forum/showthread.php?t=4312
https://www.fordbarn.com/forum/showthread.php?t=45594
Old 01-19-2020, 02:15 AM   #11
RandyinUtah
I have had engine pans on my sedan almost 40 years and never had a problem with them breaking. I was lucky and found original ford plans and had them powder coated black.
RandyinUtah is offline   Reply With Quote
Old 01-19-2020, 07:31 AM   #12
Werner
Werner's Avatar
Hallo and a big "Thankyou" at all for the unanimous positive informations.
I will order now the sheets from Brattons. They look good and were originally installed. I didn't know that until now.
Yes, the cooling of the exhaust tract is improved. When parking, less air circulates from the bottom up and the engine cools down more slowly.
The air filter is mounted upright, so no problem.
Thanks for reporting the fits. I will mount the sheet metal edges with adhesive rubber liner.
Thanks also for the photos and the links!
Werner
Citroen 11 CV, 1947
Old 01-19-2020, 10:58 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
Using adhesive liner when installing the engine pans will cause the engine pans to be a pain to remove when necessary . Lock washers work well at holding the engine pans in place for me .
It has been said that engine pans help cooling by 15% . I feel that the pans help !!! The model A needs all of the cooling help that it can get . Fifteen percent may not be that noticeable . Any improvement in cooling is good .
Old 01-19-2020, 12:34 PM   #14
DBrer
I think they help keep the engine compartment clean.
DBrer is offline   Reply With Quote
Old 01-20-2020, 11:20 AM   #15
Purdy Swoft
I agree !!!
Old 01-20-2020, 11:51 AM   #16
David R.
My AA has the bolts still on the frame and remnants of the long gone pans still under the bolts. If I ever get to that point I plan to install new ones.
David R. is offline   Reply With Quote
Old 01-20-2020, 01:04 PM   #17
31Cabriolet68-C
31Cabriolet68-C's Avatar
An adhesive rubber liner may act as a noise reducer, but it may also act as an electrical insulator... The engine pans are an integral part of the the grounding system, and need to be connected firmly enough to make an adequate electrical connection.....
TallyHo,
John B
31Cabriolet68-C is offline   Reply With Quote
Old 01-20-2020, 09:04 PM   #18
1crosscut
1crosscut's Avatar
The two places the engine pans bolt onto the oil pan are prone to cracking and breaking since the oil pan bolts are recessed a small amount inside the flange of the oil pan. I put a couple of small washers between the oil pan and the engine pan to keep the tabs straight when the bolts are tightened up.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 01-20-2020, 10:34 PM   #19
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Use the extra grd strap from tranny top to the original ground location. Even if you have pans, it’s a better grd.
Old 01-20-2020, 10:36 PM   #20
CT Jack
CT Jack's Avatar
31 Cabriolet 68-C, the best way to make sure the engine is grounded to the frame is to attach a wire to a bell housing bolt and connect the other end to the frame. Very simple to do and it works.
CT Jack is offline   Reply With Quote
