Old 11-01-2018, 03:54 PM   #1
mac101
Default Dome light
Found this dome light in the bottom of a box of parts I’ve been saving.
I don’t think it’s Model A. Does anybody recognize what it might be off of?
File Type: jpg 01582DD3-BCF8-4E9A-AA0C-8B312A5D0BF2.jpg (39.0 KB, 54 views)
File Type: jpg EC00E5C7-C29D-4D73-9DE6-373307312862.jpg (36.0 KB, 57 views)
mac101 is offline   Reply With Quote
Old 11-01-2018, 05:43 PM   #2
160B
160B's Avatar
Default Re: Dome light
It looks like Dome Lamp B in the RG&JS page 12-16 Revised 2016.
see below pdf
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 11-01-2018, 06:30 PM   #3
midgetracer
midgetracer's Avatar
it does not look Model A to me.
midgetracer is offline   Reply With Quote
Old 11-01-2018, 08:37 PM   #4
pbishop
I love the 'pic' with your reply! The kid knows best.
Reminded me of once when my son was little - I had trouble starting the 'A' and opened the distributor, touched-up all the connections and then tried to start the car. Still had no luck, then my son said, 'Dad, plug that top wire back in (coil wire) -started right up.
pbishop is offline   Reply With Quote
Old 11-01-2018, 10:47 PM   #5
daveymc29
daveymc29's Avatar
It might be from a 29 deluxe delivery? I certainly would use it on mine if I still had it. Not a show car, I might ad.
daveymc29 is offline   Reply With Quote
Old 11-02-2018, 08:45 AM   #6
Don Turley
Don Turley's Avatar
Arrow Re: Dome light
The 1929 Deluxe Delivery uses the same dome lamp as the 1929 Fordor and Town Sedan, but it is mounted on the header above the windshield. The switch is mounted next to the lamp. The switch cover plate on the 1929 Deluxe Delivery is plain, not the same as the cars. Photo attached.
Don Turley is offline   Reply With Quote
Old 11-02-2018, 08:48 AM   #7
Don Turley
Don Turley's Avatar
mac101, the dome lamp in your photo is NOT originally from a Model A Ford. Sorry, but I don't know what vehicle it came on.
Old 11-03-2018, 10:30 AM   #8
3thumbs
My dome light on my '31 Tudor has quit working. I can't see how to remove the cover and I don't want to break it. How does it come off?
Dave
3thumbs is offline   Reply With Quote
Old 11-03-2018, 12:11 PM   #9
Don Turley
Don Turley's Avatar
Dave
If your dome lamp is an original one that came equipped on the Tudor, then it has a snap ring that retains the lens in the lamp fixture. The plated bezel is part of the lamp fixture which is attached to a wood support and the roof cross bows. The bezel and fixture stays put, not removed. If you look closely, you will see where the two ends of the snap ring "almost" meet. The snap ring is at the edge of the lens and snaps into the bezel. You will need to pry one end of the snap ring with a thin flat blade screwdriver or knife. When the snap ring turns loose from the fixture, be prepared to catch the lens from dropping and breaking. You might want an extra hand there to catch the lens. Once the lens is removed, you can replace the bulb. If the bulb is not the problem, then you will need to check the wiring.
Old 11-09-2018, 05:17 PM   #10
3thumbs
I found the snap ring, and it looks just like you said. However, I cannot get anything under the ends of the snap ring. It is really tight, and doesn't want to come out at all. The dome light worked the last time I tried it, probably a year ago. The car has been converted to 12v so I think it is the bulb.
Old 11-09-2018, 05:39 PM   #11
3thumbs
I just managed to get the lens out and the bulb is good. Must be the wiring.
Dave
Old 11-10-2018, 11:01 AM   #12
Badpuppy
If it's an original, remove the bulb and push the socket inward and work it back and forth a few times. The contact may have corroded a bit. The rotating part may have slipped away from the contact also, just applying a bit of pressure while turning it on may do the job.
Badpuppy is offline   Reply With Quote
Old 11-10-2018, 11:44 AM   #13
duke36
Looks like the one in some mid 30's Chrysler products with an oval shape and integral switch. Mine has the snap ring soldered to the plated outer frame to retain the lens.
duke36 is offline   Reply With Quote
