Old 09-13-2011, 10:28 AM   #1
jnunez1955
Default Front Cross Member Mount on Model A frame DIMENSIONS
i piecing together a model a coupe.
I have the frame rails and a 30's cross member.
I was wondering if any one could give me the dimensions and measurements so i know im welding this thing proportionally in the correct spots.
-I need to know how far away the left and right rail is (from the center to center of the rail) of where the front cross member is suppose to be.
-and i need to know how far back the the front cross member is suppose to be according to the tip of the front frame horn. (from the midline of where the leaf spring mounts, to the tip of the rail)
thanks for the help...hopefully there is someone on here that could help
jnunez1955 is offline   Reply With Quote
Old 09-13-2011, 10:29 AM   #2
jnunez1955
Default Re: Front Cross Member Mount on Model A frame DIMENSIONS
this is for a 30-31 coupe frame also.
Old 09-13-2011, 11:50 AM   #3
doug shouldis
Go to wescotts auto. on home page go to tech. then go to frame specs
doug shouldis is offline   Reply With Quote
Old 09-13-2011, 12:35 PM   #4
jnunez1955
thanks doug
Old 09-14-2011, 04:01 PM   #5
Richard Lorenz
If the Wescotts frame dimensions are the ones that I am thinking of, some of them are wrong.
Richard Lorenz is offline   Reply With Quote
