10-18-2020, 06:06 PM | #1 |
lug nut removal
Yesterday I found a video on removing the model a stud but now I can not find it. Could you help me out please ??
10-18-2020, 06:29 PM | #2 |
Re: lug nut removal
Why do you need a video to show you how to take off lug nuts?
10-18-2020, 07:24 PM | #3 |
Re: lug nut removal
My question was about removing the stud not the lug nuts or am I wrong ??
10-18-2020, 10:32 PM | #4 |
Re: lug nut removal
This isn't a video but is shows how to change the studs.
http://www.fordgarage.com/pages/swaging.htm |
10-19-2020, 12:03 AM | #5 |
Re: lug nut removal
Please read your title, you ask about lug nuts. The question in the post was edited after I posted.
10-19-2020, 12:13 AM | #6 |
Re: lug nut removal
10-19-2020, 05:37 AM | #7 |
Re: lug nut removal
“According to Google”.
The lug that shows up in lug nut or lug wrench doesn't seem to be directly connected. Instead, it comes from a word that meant a projecting part. Originally, it came from a Scandinavian word that meant the ear flap of a cap, or the ear itself. In the 1930s, lug also meant a lout, a sponger, a bozo, and a lowlife. |
10-19-2020, 10:15 AM | #8 |
Re: lug nut removal
Probably comes from when using wood wheels, like on a Model T, there is a lug that goes between the wheel rim and the felloe of the wood wheel, and the "lug nut" tightens down against the lug.
Couldn't find a picture. In Canada we just call them wheel nuts.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 10-19-2020 at 10:28 AM. Reason: Addition |
10-19-2020, 10:29 AM | #9 | |
Re: lug nut removal
The swage cutter I use slides over the threaded portion of the hub bolt and is turned slowly in a knee milling machine. The cutter slowly removes the area of the hub bolt where the bolt was riveted. Once this is complete, the bolt can be tapped thru the backside of the hub. |
10-19-2020, 04:24 PM | #10 |
Re: lug nut removal
Yes, wheel nuts on wheel studs here too, just like manifold nuts on manifold studs. Strange!
