Old 10-17-2020, 02:51 PM   #1
old31
Default Distribution block for 6 volt
I am looking to add a 6 volt distribution block for my 6 volt 31.
Does anyone have any recommendations on blocks or tips for adding one.
Old 10-17-2020, 04:24 PM   #2
Curtis in MA
Default Re: Distribution block for 6 volt
Brattons sells the A panel. Attaches to the inside firewall. Hard to work on up there but can't be seen.
Curtis in MA is online now   Reply With Quote
Old 10-17-2020, 04:45 PM   #3
shew01
shew01's Avatar
https://www.brattons.com/a-plate-acc...use-panel.html
shew01 is offline   Reply With Quote
Old 10-17-2020, 04:55 PM   #4
Patrick L.
Patrick L.'s Avatar
In addition to the Bratton fuse block, any local auto parts store should have one for about $10.
Old 10-17-2020, 05:43 PM   #5
shew01
shew01's Avatar
Very true. Amazon has a bunch too.
Old 10-17-2020, 07:00 PM   #6
CarlG
CarlG's Avatar
I have this one on my firewall. I think I got it on Amazon quote a while back. Also available at Marine supply stores.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-17-2020, 09:33 PM   #7
PalAl
PalAl's Avatar
This is what I did.....
PalAl is offline   Reply With Quote
Old 10-18-2020, 08:18 AM   #8
old31
Carl I was looking at this one from Amazon but it said for 10-32 volt. So I wasn't sure it would work for a 6 volt.
Old 10-18-2020, 09:55 AM   #9
Badpuppy
Fuse blocks work at any voltage up to the insulation rating. The thing to be concerned with is current capacity, which implies heat rating.
Badpuppy is offline   Reply With Quote
Old 10-18-2020, 12:18 PM   #10
PalAl
PalAl's Avatar
Del-City may have what your looking for
https://www.delcity.net/store/Fuses-&-Fuse-Accessories/
Old 10-19-2020, 04:51 PM   #11
Bob-A
Bob-A's Avatar
Cool Re: Distribution block for 6 volt
Besides the usual single fuse block mounted off my starter switch. I attach one on my generator off of a cut-out mounting screw. This protects the main electrical system from the headlights/horn in case they develop a short. The single fuse blocks will mount on either side of the starter switch. So you can run two single blocks off of it. Also, look on eBay I've bought "antique'y looking*" multiple fuse stand alone blocks off of it.
Bob-A
*I try and stay "period correct" when I modify my "A". If it is not possible
then the item I use. I try and make it look "period correct" or antique'y,
as I call it.
Bob-A is offline   Reply With Quote
