Old 08-11-2020, 08:03 AM   #1
kketchmark
kketchmark's Avatar
Default Mercury Flathead on Craigs list MN
https://minneapolis.craigslist.org/a...175239752.html
What you think? Is it worth anything? Let me know.
49 F-1 8BA
kketchmark is offline   Reply With Quote
Old 08-11-2020, 08:16 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Mercury Flathead on Craigs list MN
At most, that incomplete engine is worth scrap value. Maybe more if you need parts.
Way over priced. If it was any good it wouldn't have been left outside to seize and rust away.
I would pass.
Old 08-11-2020, 08:19 AM   #3
flatjack9
flatjack9's Avatar
The crank is worth at least at least 2- 3 hundred.
Old 08-11-2020, 10:34 AM   #4
19Fordy
19Fordy's Avatar
It all depends on condition of the crank. It better be very good for that kind of money.
There's one on Ebay right now.
Old 08-11-2020, 10:45 AM   #5
tubman
tubman's Avatar
"No oil pan" and the top side looks like that? There has too be a reason why the pan was removed and then the engine dumped outside. The crank would be a gamble at best.
Old 08-11-2020, 10:54 AM   #6
rustythumb
has ford intake & carb.
rustythumb is offline   Reply With Quote
Old 08-11-2020, 11:49 AM   #7
Los_Control
I recently seen a running merc for $500 with transmission.
I just bought a 1951 8BA for $100, guy advertised it for $300. I shot him a offer for $100 ... I told him to go ahead and sell it, but if not sold and before throwing it in the iron pile, I would give $100. He said come get it. .... The pics of it was in the shop, when I picked it up, he already had it back in the iron pile
It was stuck and I figured would be good parts. Still a crap shoot, but might end up being a good block to rebuild.
IMHO, a stuck flathead, is way to iffy for $400
Los_Control is offline   Reply With Quote
Old 08-11-2020, 11:57 AM   #8
bobH
Makes me wonder... I also note that the flywheel and clutch are NOT the Merc version that I am familiar with.
bobH is offline   Reply With Quote
Old 08-11-2020, 12:08 PM   #9
cas3
you would want the rods too, so you cant get too violent tearing down a stuck motor. whats up with those things around the spark plugs? never seen that before. new london is the home of windy hill auto parts. used to be one of the biggest antique junk yards in the country, but same old story, owner retired, kids scrapped most of it when steel was high
Old 08-11-2020, 12:38 PM   #10
Tim Ayers
Agreed. A hunge, no more. If asking more, would need money back guarantee that the crank is good.
Old 08-11-2020, 02:28 PM   #11
Krylon32
Crap Shoot
Krylon32 is offline   Reply With Quote
Old 08-11-2020, 02:47 PM   #12
scicala
scicala's Avatar
I agree. If it's a '51 Merc engine (255) like the add says, then it has the wrong intake and carb.
Sal
scicala is offline   Reply With Quote
Old 08-11-2020, 02:50 PM   #13
Lanny
Lanny's Avatar
4 or 5 weeks ago, about 20 miles east of New London, a fellow that was moveing
wanted $75 for an engine described about what that one looks like. He called me
a week later and said he would give me the engine if I would come pick it up.
It was about 75 miles from me and I was really busy that week, so I never took
the time to go after it... For Free I'm sure someone closer went after it. Oh well.
Maybe this is the same engine, maybe not...
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 08-11-2020, 03:16 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Doesn't this say "1CM" on the counterweight? Does that not indicate '51 Merc? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-11-2020, 06:06 PM   #15
flatjack9
flatjack9's Avatar
Yes it does. Doesn't make any difference what else is on the engine.
Old 08-11-2020, 08:13 PM   #16
flatford8
flatford8's Avatar
What are those little cup things around the spark plugs?......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 08-11-2020, 08:25 PM   #17
19Fordy
19Fordy's Avatar
Years ago weren't there inserts you could insert to raise the height of your spark plugs if the engine burned oil?
I recall something like that was available. Look here.
https://www.google.com/search?q=spar...hrome&ie=UTF-8
Old 08-11-2020, 08:43 PM   #18
flatford8
flatford8's Avatar
I’ve used those “no-foul” ends on an OT motor that used to foul plugs. I haven’t seen little cups like that before.......Mark
Billy Joe Shaver
Old 08-11-2020, 10:59 PM   #19
GB SISSON
GB SISSON's Avatar
Doesn't look horribly stuck to me. The bottom end being so oily makes me think the pan was recently pulled to verify and photograph the bottom end and the fact it has a merc crank. I have had 4 merc cranks and read many books/articles describing how to tell a merc crank from a ford. I have never seen or heard of one stamped as such. That's too easy. I continue to learn.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 08-12-2020, 12:16 AM   #20
cas3
i agree with GB, never heard of the stamp. i always thought it was the size of the clean out plug, which is not a for sure, and then measure the stroke
