Old 06-20-2020, 11:08 AM   #1
Werner
Werner's Avatar
Default Selfmade a top boot
Hi,
does someone have a sewing sheet / construction plan of the 'top boot' for the folded roadster roof (standard)?
The high additional costs 125 shipping + 26% EU / BTW on the total amount make me consider sewing this tarpaulin myself.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-20-2020, 02:45 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Selfmade a top boot
Hi Werner! Best advice is to look at pictures until you have a "feel" for what your dealing with. I would suggest then using paper or thin cardboard to make a pattern. Use an upholstery sewing machine to avoid problems.
Tacoma Bob is offline   Reply With Quote
Old 06-20-2020, 08:26 PM   #3
Nosetime
Nosetime's Avatar
Werner, Go directly to the Sailrite website. So much info, and the pattern material I bought...I think is called scrim? There is a lot of teaching video on youtube from Sailrite.
Nosetime is offline   Reply With Quote
Old 06-21-2020, 03:56 AM   #4
johnbuckley
johnbuckley's Avatar
Agree with #2 above. Woolies in Uk have all fabric and fittings needed. I used an ordinary domestic sewing machine , made a paper pattern with quaility paper ( not newspaper) and end result was an accurate top boot that fitted the car neatly.
johnbuckley is offline   Reply With Quote
Old 06-21-2020, 10:32 AM   #5
Werner
Werner's Avatar
Hi at all,
thank you for the hints. My problem is also that I have never seen this part before. Only on small pictures if it is covered.
Werner
Citroen 11 CV, 1947
Old 06-21-2020, 06:12 PM   #6
Vern
Vern's Avatar
Werner, here are some photos of the top boot for my '28 roadster. I don't know if it is correct per the Judging Standards, but it came with the top. I hardly ever put it on, it's kind of a PITA. If you want more, let me know. Vern
Vern is offline   Reply With Quote
Old 06-22-2020, 04:42 PM   #7
Werner
Werner's Avatar
Vern, thank you for the helpful pictures. I see snap fasteners on the front hem to the backrest. I can not assign them. Where are they sitting at?
Werner
Citroen 11 CV, 1947
Old 06-22-2020, 05:23 PM   #8
Vern
Vern's Avatar
Werner, I think the snaps are to attach at the top rail behind the seat, but I'm not certain. There are no snap fasteners behind the seat top on my roadster.
Old 06-22-2020, 11:41 PM   #9
Brad in Germany
Brad in Germany's Avatar
Hi Werner,
I looked though some original Ford factory photos showing 1928-1929 Roadsters with top boots and found the following photos that might be of help. I have cut out and enlarged the top boots so that you can best see how they look and fit and also the position of the fasteners, etc:
Note not only the position of the various snaps, but also the two slots where the roof tie-downs protrude through the top boot at the two top rear edges/corners of the boot.
Hope that helps.
mit Ford Grüße aus den USA,
Brad
PS: Are you touring in the Harz with the Model A group this week?
Brad in Germany is offline   Reply With Quote
Old 06-23-2020, 12:10 AM   #10
al's28/33
al's28/33's Avatar
I would like to see an image of a Phaeton with the boot on and how the rear snaps get snapped in place when you have a trunk box sitting right up against the body.
I have never been able to get mine to SNAP!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 06-23-2020, 08:52 AM   #11
Brendan
Brendan's Avatar
i just take my top completely off
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 06-23-2020, 07:43 PM   #12
Vern
Vern's Avatar
Brad, thanks for posting the close-up pictures!
Interesting that none of the snaps along the top of the seat back are fastened to anything. I though it was just me.
Old 06-24-2020, 04:57 AM   #13
Bruce of MN
Bruce of MN's Avatar
What is the function of the snaps then? I've never observed a roadster driving, but I assume the open leading edge billows up like an air brake or vinyl tops do on older cars?
Bruce of MN is offline   Reply With Quote
Old 06-24-2020, 06:50 AM   #14
SAJ
SAJ's Avatar
The snaps on my standard roadster boot fasten to their counterparts on the vertical inside surface (ie not the horizontal top surface) of the wooden rail behind the seat back. If not fastened here the boot will billow in the wind at speed as mentioned.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 06-24-2020, 03:45 PM   #15
Werner
Werner's Avatar
Thank you for the particularly helpful pictures!
Because therfore the working time is expansive high, so I postpone the production of the large boot until the winter time.
But I am currently sewing a small tarp that prevents the folded roof from fluttering and look a little bit better. I made the test pattern out of an old bed-sheet. It is attached to the roof rails eyelets at the bottom, together on the nipples. Then the roof get folded and the other end of the tarp is popped onto the front roof buttons with snap bottons. Then that can't flutter.
The testing fits. Tomorrow I do it with black thick linen fabrik.
Werner
Citroen 11 CV, 1947
Old 06-25-2020, 01:49 PM   #16
Werner
Werner's Avatar
Hi,
done the small part. Looks better than before and nothing flutters anymore.
Werner
Citroen 11 CV, 1947
