Old 05-01-2020, 10:34 AM   #1
Mart
Mart's Avatar
Default Flatty Friday: This Crusty Flatty then. Will it Run??
So it's the one you've been waiting patiently for.
The Crusty Flatty is finally in a position to attempt a start.
Probably better let the video do the talking.
Please watch directly in YouTube so the like and subscribe buttons are available.
I'm trying to build the channel so thanks if you can support by clicking the buttons. It helps the algorithms.
Cheers then!
Mart.
https://youtu.be/xShxw9CsiDE
Old 05-01-2020, 12:36 PM   #2
done4
done4's Avatar
Send a message via Yahoo to done4
Default Re: Flatty Friday: This Crusty Flatty then. Will it Run??
Good for you Mart!!!!! This has been a blast to say the least. Thanks for sharing your adventure.
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 05-01-2020, 02:48 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
Hey Mart - noticed that when you were cranking it over earlier in the video that there was some blow-back through the carb. What this usually tells me is that an intake valve is not seating correctly. This can be due to adjustment, or it is leaking on the compression stroke. If you're having a bit of back-firing . . . this could surely be the issue. Just wanted to point that out to you . . .
Old 05-01-2020, 02:55 PM   #4
Bored&Stroked
You might do a compression check on all cylinders . . . and if you just happened to have a leak-down setup, I'd leak it down to see where the valve sealing issue exists. You may also be able to isolate it by pulling one plug wire at a time and see if the backfiring goes away.
Old 05-01-2020, 03:02 PM   #5
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Good video , been there in yer position many many times over the years , pat yer self o the back that it is running and now take yer time to figure it out ......
And i thought i had a accent ???? rbg :.)
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-01-2020, 06:41 PM   #6
Mart
Mart's Avatar
Thanks for the response, fellas.
As there is a delay with getting the videos out, I have already been able to work out what was wrong with the motor. All will be revealed in an upcoming video.
Thanks again.
Mart.
Old 05-01-2020, 08:08 PM   #7
RalphG
RalphG's Avatar
Looking and sounding good Mart. Those Ford starters are tough. I had to use 12 volts to the starter when I was first getting the 52 Merc started after it's long rest in the woods. Now its back to starting easy on six volts.
RalphG is offline   Reply With Quote
Old 05-01-2020, 09:47 PM   #8
Graeme / New Zealand
Graeme / New Zealand's Avatar
Well done Mart !
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 05-02-2020, 03:46 AM   #9
flatford8
flatford8's Avatar
Nice job!.....looking forward to the next show!!......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 05-02-2020, 09:16 AM   #10
RalphM
RalphM's Avatar
Love it Mart! I Kept thinking, I wish I was there to put my hand over the carburetor for you.
RalphM is offline   Reply With Quote
Old 05-02-2020, 09:22 AM   #11
41ford1
41ford1's Avatar
Good on you Mart!! You saved another one.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 05-02-2020, 11:14 AM   #12
flatford8
flatford8's Avatar
Your getting good at the “cliff hangers” too...... Mark
Billy Joe Shaver
Old 05-02-2020, 12:05 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
Happy to see it running.
Incidentally, your static issues while recording may possibly be caused by florescent lights if you have them.
Old 05-02-2020, 01:30 PM   #14
Mart
Mart's Avatar
Yes I do, Merc, thanks for the tip. I hadn't thought of that.
Thanks for all the comments and support guys.
Mart.
Old 05-02-2020, 07:38 PM   #15
Sparky79
It was great to hear it run gives me a little hope I can do the same with my 8ba. It's very cool to watch it from beginning of the process to the end.
Sparky79 is offline   Reply With Quote
Old 05-04-2020, 05:11 PM   #16
Mart
Mart's Avatar
Thanks Sparky. It's been a lot of work, but fun, hobby work if you know what I mean.
Mart.
Old 05-04-2020, 06:35 PM   #17
Brendan
Brendan's Avatar
Good Job Mart! i look forward to the crusty flaty vids!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Thread Tools
Display Modes
