Old 01-06-2015, 07:59 AM   #41
Flysafe
Default Re: Oil pan 59AB photos
Hello all,
Some progress in the drawing, left side block, the lines of the back is not done yet. Now they are aligned.
All the best,
Jorge
Flysafe is offline   Reply With Quote
Old 01-24-2015, 03:41 PM   #42
Flysafe
I need some help, which side have the bigger angle in the valves?
Old 01-24-2015, 04:25 PM   #43
JSeery
JSeery's Avatar
Are you looking for the angles? 52.09 on the left and 49.36 on the right.
Old 01-26-2015, 08:02 AM   #44
Flysafe
Thank you .
Old 02-01-2015, 10:31 AM   #45
Flysafe
Hello all,
Now with a few more things, the funny part will begin, extrude all the lines.
The valves sets is done with the correct angle. I will need to resize some parts not serious.
Old 02-04-2015, 07:57 AM   #46
Flysafe
Does anyone has a piston for a bore 3.1875 that can take a measurement?
-Height,
-From the bottom to the middle of the piston pin,
-The pin diameter.
Thank you so much.
Old 02-04-2015, 11:33 AM   #47
JSeery
JSeery's Avatar
See if any of this helps. This piston is from a 1948 59a engine, it is domed top, 3.188 +.040 (original 3.188 bored std .040 over).
From top edge of piston to bottom of longest part of skirt: 2.960
From top edge of piston to bottom of shortest part of skirt: 2.700 (not including notch)
Width of longest part of skirt: ~1.250
Width of shortest part of skirt: ~1.250
It is curved between these sections.
From top edge of piston to top of dome: ~.250
Starting a top edge of piston working down to shortest part of skirt (not including notch).
Top edge to top piston ring: .250
Top piston ring grove: .096
Top piston ring to second piston ring: .156
Second piston ring grove: .096
Second piston ring to third piston ring: .100
Third piston ring grove: .188
Third piston ring to top of piston pin: .268
Piston pin: .750
Bottom of piston pin to bottom piston ring: .170
Bottom piston ring grove: .183
Bottom piston ring to bottom of skirt: .440 (not including notch)
From Top edge of piston to center of piston pin: ~1.530
From center of piston pin to bottom of skirt: ~1.170
Piston Pin diameter: .750
These are measurements straight from a piston using calipers and include measuring errors I am sure!
Old 02-04-2015, 11:35 AM   #48
JSeery
JSeery's Avatar
For some reason the photos didn't load the first time.
Old 02-05-2015, 06:44 AM   #49
Flysafe
Thank you so much JSeery.
Old 02-05-2015, 10:22 AM   #50
Flysafe
Earlier I do this type of piston, can be used in this engine model?
Old 02-05-2015, 11:03 AM   #51
JSeery
JSeery's Avatar
There are 3 ring and 4 ring pistons. I believe the original design from Ford was the 4 ring and the 3 ring was a more modern replacement. Not sure it would make any difference for what you are doing, a lot of the current rebuilds use the 3 ring style.
Old 02-06-2015, 07:06 AM   #52
Flysafe
Thanks.
Old 02-08-2015, 09:30 AM   #53
Flysafe
Hello all,
Some of the lines after extruder.
Old 03-25-2015, 04:53 PM   #54
Flysafe
Some progress in the design.
Old 03-30-2015, 11:42 AM   #55
Flysafe
Hello all,
Exhaust channels done, and e few holes. Start the front end of the block.
Old 04-06-2015, 10:44 AM   #56
Flysafe
Hello all,
The 59 AB block have the yellow line that I made?
The block 8 BA have this fill.
Thank you so much.
Old 04-07-2015, 12:15 PM   #57
Flysafe
Hello all,
I 'm working in the front end of the block, I will need some help, someone have any photos where I can see the front end of the block 59 AB without the water pumps and the distributor cover? I already made a google search but not find anything.
Thank you so much for the help.
All the best,
Jorge
Old 04-07-2015, 12:51 PM   #58
JSeery
JSeery's Avatar
I can add some in about an hour.
Old 04-08-2015, 05:17 AM   #59
Flysafe
Old 04-08-2015, 11:44 AM   #60
JSeery
JSeery's Avatar
I'm easily distracted! But here are 4 shots of 59a block. This is a 48 block (as far as I know) out of a Truck.
Thread Tools
Display Modes
