12-08-2013, 02:06 PM | #1 |
Wire spokes
Looking for best/ fastest/ easiest way to strip paint from rims/ spokes
12-08-2013, 02:10 PM | #2 |
Re: Wire spokes
I've done this before. Put card board down lay wheel on it. I have an old spray gun i put stripper and cheap lacquer thinner in and spray. You get real good coverage this way.I will be doing this next week.
12-08-2013, 02:18 PM | #3 |
Re: Wire spokes
best fastest way to strip wheel clean is to farm it out to a shop that
does powder coating. had mine done with painted powder coat for 125 a wheel and they look brand new now. \ fredski |
12-08-2013, 03:19 PM | #4 |
Re: Wire spokes
Old fashioned LYE & WATER, in a metal tub will do dandy!
Chief & I once stripped a '34 Chev. to the METAL, & it must have had 19 coats of crackled paint!!!!!! Bill W.
12-08-2013, 06:14 PM | #5 |
Re: Wire spokes
In my opinion, sandblasting is the best method. It gives a slightly rough finish so the coating - primer or powdercoating gets some bite to adhere better. Here in the Twin Cities, there are several places that will blast a wheel for $20 to $35. These a large sandblasting outfits that can do a rim in a very short time. Personally I blasting my own rims so I can prime them quickly after blasting, however it takes about an hour to do each one. Once sandblasted, you can see any defect in the metal like cracks in the hub or dings. What you can't see for sure is whether a lug nut hole is enlarged or the rim is bent - wobble). I have done 12 or 15 so far with my TIP (100# for sand) pressure blaster and am happy with the results.
Rusty Nelson |
12-08-2013, 06:16 PM | #6 |
Re: Wire spokes
12-08-2013, 07:14 PM | #7 |
Re: Wire spokes
GOOD TIP, Thanks! Cornstarch also makes WIMPY gravy or pasta sauce stand up & take notice It also makes yo' thin milkshake thicken up Bill W.
12-08-2013, 07:24 PM | #8 |
Re: Wire spokes
If you're in the western US Les Schwab Tires will sandblast AND powdercoat for about $35.00 per wheel.
Larry Seemann |
12-08-2013, 07:27 PM | #9 |
Re: Wire spokes
Sand blast
12-08-2013, 07:49 PM | #10 |
Re: Wire spokes
Just had mine done at Les Schwab, media blasted & powder coated $30.50 each plus tax. They look great. Took 7 days. no mess to clean up, no cleaning products or paint to buy.
12-08-2013, 07:59 PM | #11 |
Re: Wire spokes
Where I have my engines oven backed and shot peend. They come out of the shot peen like new. Everyone around my area have there wheels done there. It don't take long and not expensive. Walt
12-08-2013, 09:07 PM | #12 |
Re: Wire spokes
Sandblast and paint them. This is how I do them and it always works well.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
12-10-2013, 05:16 PM | #13 |
Re: Wire spokes
Thanks to all for the suggestions, looking forward to seeing the finished rims, having them blasted and powder coated. Tom
