11-16-2013, 12:26 PM | #1 |
wireless turn signals
11-16-2013, 12:40 PM | #2 |
Re: wireless turn signals
And here I thought they were always called hand signals.
11-16-2013, 01:26 PM | #3 |
Just bought the same system on ebay for $49.
Gene USN |
11-16-2013, 02:17 PM | #4 |
I like these - pricey but very well designed.
Smart Signals Right now they are out of stock & you have to put down a $25 deposit.
Owning an antique car is "start fixing one thing, find four other things that need fixing." Lather, rinse, repeat. |
11-16-2013, 04:24 PM | #5 |
Pretty neat, will be interesting to see if they work with the engine RUNNING. Would love to see a follow-up on this!!!!
They were complaining about smartsignal with interference with the ignition on the MTFCA forum Last edited by Russ Koch; 11-16-2013 at 04:34 PM. |
11-16-2013, 06:43 PM | #6 |
11-16-2013, 07:33 PM | #7 |
Is seems like this is a good products but what about the front of the car? Do you need 2 systems for front and back?
11-16-2013, 08:13 PM | #8 |
Can someone please post an ebay link or an item number for these. I can't seem to locate on ebay.
Many Thanks
Adjust your points with gentle blows of a 2 pound hammer |
11-16-2013, 08:35 PM | #9 | |
Configured for the back of your motorcycle or helmet but adaptable to the back of your Model A. Three push buttons within reach of the operator - no auto reset, of course. Joe K
Shudda kept the horse. |
11-16-2013, 08:42 PM | #10 |
I found it on ebay under sporting goods.
11-16-2013, 09:03 PM | #11 | |
11-16-2013, 09:26 PM | #12 |
The Smart Signals look like a better operation. The Elights seem to me that some drivers behind you might interpret the flashing right turn signal as a left turn signal because it is on the left side of the car. People aren't always so bright, and if a hand signal confuses them, a flashing light on the left side of the car, even though it points right, might also confuse them. I like the idea. I hope in the next iteration they come up with something like Smart Signals in the $100 range.
11-16-2013, 09:33 PM | #13 |
My cheapy t/s will be mounted high up on the huckster top rail and in the center, but the idiots will probably still not pay attention.
Gene USN |
11-16-2013, 10:12 PM | #14 |
Wondering if the same control would operate 2 units. The front would be installed upside down in order to flash the correct direction.
11-16-2013, 10:54 PM | #15 |
Sad but true.
11-17-2013, 12:34 PM | #16 |
Jim, regarding the Smart Signals. I have been interested in this product for some time. I know the seller will answer FAQs but I would like to know from an actual owner. Do they "grip" well enough on the Model A bumpers? Where do you mount the dash unit. Can I buy new batteries locally, at a Batteries Plus or on Amazon etc, or only from Smart Signal? If some boob, like me, breaks one signal or another boob backs into a signal, can these be coded and replaced, or does a whole set need to be repurchased ? They are pricey, but if what they say is true, they a worth it and can be resold if they are no longer of use or you sell the car. Ron
11-17-2013, 02:04 PM | #17 | |
Google CR2032 battery, lots of sources the link below sell them for $1.37 ea. http://www.alliedelec.com/search/pro...32%20Energizer
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
11-17-2013, 02:28 PM | #18 | |
11-17-2013, 02:40 PM | #19 | |
As for the batteries, I don't suspect that will be an issue for some time either but when I'm ready to get new batteries I will most likely contact the manufacture for new ones. If one unit should be damaged and fail or fall off, they can setup and sell you one new unit. So all I can say is so far is they work as advertised and I'm a whole lot happier that I can drive the car late at night with running lights on all around the car and the signals are very very bright which is great. These units sure beat wiring the car for signals and work even better when you have a trailer that isn't wired or is being used by someone who's power/directional connections are not the same as yours. I hope this helps you out. Good luck! |
11-17-2013, 02:51 PM | #20 |
At that cost and looking at the shape I would be surprised if they were rechargeable!
