Old 10-21-2020, 08:27 PM   #1
druebates
Thumbs up 1930 Model A Gears Grind After New Clutch Install
Just had a new clutch installed in my 1930 Model A Roadster convertible. I can no longer shift from 1st to 2nd or 2nd to 3rd when double clutching. never had this problem before new clutch. Mechanic says that clutch DOES disengage and has adjusted the clutch linkage. Any thoughts? Thanks you! Drue Bates - Arizona
druebates is offline   Reply With Quote
Old 10-21-2020, 08:39 PM   #2
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
Default Re: 1930 Model A Gears Grind After New Clutch Install
I would start by making sure the transmission is full of oil. That's how they act when they are empty.
I'm assuming it acts normal from a stop. As in you can put it in gear at idle and take off fine?
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 10-21-2020, 08:57 PM   #3
Synchro909
Synchro909's Avatar
If the gearbox is not properly supported in the time between the spline on the input shaft engaging the clutch plate and getting a few bolts in the bell housing, the clutch plate may be bent. If that has happened, it will drag when the pedal is depressed. That might be your problem. The only fix it to replace the bent clutch plate and don't do it again.
Old 10-22-2020, 07:08 AM   #4
Big hammer
Did they pull the engine to change the clutch ? If so they may have bent the throttle linkage ! If your idle speed is to high you'll grind gears.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 10-22-2020, 07:45 AM   #5
jwilliams81
jwilliams81's Avatar
As has already been said. Make sure there is oil, the proper amount of oil, in the transmission. Also make sure the correct oil is used! A lot of people won't buy the correct 600W oil and complain about just what you describe. 600W is much different than regular gear oil you can buy off the shelf, it really does make a huge difference.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 10-22-2020, 08:05 AM   #6
rocket1
druebates welcome to the Ford Barn.I see it is your first post.I do not see your location sometimes helpful, there might be someone near by that could help you.
rocket1 is offline   Reply With Quote
Old 10-22-2020, 08:11 AM   #7
edzaha
Why has nobody asked the obvious question, was the pressure plate adjust properly, and is there the correct pedal free play?
edzaha is offline   Reply With Quote
Old 10-22-2020, 09:41 AM   #8
Will N
Will N's Avatar
Bingo. The first thing I would check is if the pedal free play is adjusted properly.
Will N is offline   Reply With Quote
Old 10-22-2020, 09:58 AM   #9
Greg Jones
Greg Jones's Avatar
Pedal free play and engine idle speed are two places I would look, too. There is a guy in our club who has his idle set to "excessively fast" and is always grinding the gears, even when at a full stop to put it into first gear. I keep telling him is idle is too fast, and he says "nah I just need a new transmission." Sure, that should fix the problem....not.
Greg Jones is offline   Reply With Quote
Old 10-22-2020, 10:29 AM   #10
Patrick L.
Patrick L.'s Avatar
Why was the clutch replaced ?
Are you now able to shift from neutral into any gear without grinding ?
How much pedal free-play is there ?
Were the pressure plate fingers checked/adjusted prior to or upon installation ?
You really shouldn't have to double clutch upshifts.
Old 10-23-2020, 11:11 AM   #11
jerrytocci
can the disk be installed backwards ??
jerrytocci is offline   Reply With Quote
Old 10-23-2020, 02:10 PM   #12
Patrick L.
Patrick L.'s Avatar
I'm going to say no, but, I've learned to never say never. Some folks seem to be able to do the impossible.
Old 10-23-2020, 04:08 PM   #13
wwirz
Easy stuff first. Check for the correct transmission oil. Make sure your idle is set properly. It is a big deal to tear into the pressure plate and disk again.
wwirz is offline   Reply With Quote
Old 10-24-2020, 06:06 AM   #14
Jacksonlll
Jacksonlll's Avatar
Put the car in neutral with the clutch out and rev the engine. Then push the pedal down to the floor and wait about 20 sec. It should go into gear with no grinding. If not, adjust the clutch.
Old 10-24-2020, 08:05 AM   #15
jw hash
jw hash's Avatar
I`m going with Edzaha. on the pressure plate adjustment. I replaced a clutch last month. the pressure plate was a rebuilt. I always bolt them up and check for the right finger height, and they were way off. by a 1/2" that is a lot. if the fingers are to low the clutch might not disengage. I will add the flywheel was resurfaced correctly. if you have the flywheel resurfaced it has to be done correctly, if not it will effect the adjustment of the pressure plate.
jw hash is offline   Reply With Quote
Old 10-24-2020, 02:53 PM   #16
jerrytocci
Please post the fix
Old 10-28-2020, 08:33 AM   #17
History
History's Avatar
That's where my brain goes with anything that has a mechanical linkage to the clutch or hydraulic for that matter. I'd start here and the throttle as mentioned.
History is offline   Reply With Quote
Old 10-28-2020, 11:02 AM   #18
Bob C
The OP has never been back since he posted the question.
Old 10-28-2020, 11:24 AM   #19
warhorseracing
warhorseracing's Avatar
Either pfishing or he fixed it.
warhorseracing is offline   Reply With Quote
