Old 08-03-2020, 06:57 PM   #1
95476
95476's Avatar
Default '33 Sedan Delivery, what goes here ?
I am doing the heavy metal work on the body and want to find out what the holes at the ends of the rear drip rail are for.
Were there screws in those holes ?
Retainers for rubber ?
Any info is appreciated.
Thank you
95476 is offline   Reply With Quote
Old 08-04-2020, 07:01 AM   #2
rockfla
rockfla's Avatar
Default Re: '33 Sedan Delivery, what goes here ?
Is this the area you are speaking of??? It doesn't appear to have anything there??? OR is this the top insert opening?? IF its the insert opening< I don't recall anything there on our 35 Delivery (IF the construction in 35 was like 33-34).
Old 08-04-2020, 09:51 AM   #3
Digger
Digger's Avatar
I should have kept that 33 SD....darn
Digger is offline   Reply With Quote
Old 08-04-2020, 10:28 AM   #4
rockfla
rockfla's Avatar
I should have "bought" that from you!!! I drooled and dreamed about that one for the whole time you had it for sale. Obviously, I stole a picture of it!!!
Old 08-04-2020, 10:43 AM   #5
rockfla
rockfla's Avatar
OR could it be the rear door opening???? Not sure this angle helps either but worth a shot!!!
Old 08-04-2020, 12:51 PM   #6
Digger
Digger's Avatar
Rock, I see your avatar photo is at Pebble. Did we ever meet when you came over?
Old 08-04-2020, 12:58 PM   #7
rockfla
rockfla's Avatar
Not that I am aware of Unless you were there the day of the show and we talked about the car, If you did I don;t remember an introduction? Sorry!! I don;t know your real name??
Old 08-04-2020, 07:56 PM   #8
95476
95476's Avatar
My car has the same drip rail. At each end there is a hole about 1/2 inch from the end. I had a '36 sedan delivery and it never had them.
I am thinking they are screw holes to secure the ends of the rail to the body.
I am going to TIG them up.
Thank you.
Old 03-22-2021, 12:21 PM   #9
davidk
There is a screw in each of the holes at the end of the drip rail.
davidk is offline   Reply With Quote
Old 03-22-2021, 06:29 PM   #10
mercman from oz
mercman from oz's Avatar
These 1933-1934 Ford Sedan Deliveries are great looking vehicles. The lines are just perfect.
