Old 05-24-2022, 08:59 AM   #1
rockfla
rockfla's Avatar
Default Help with a measurement
Anyone have a 21 stud water outlet gasket you could give me two quick measurements off of so I can get two blank off plates cut?? I need bolt center to bolt center And width and height measurement’s. Thanks In advance!!
Old 05-24-2022, 09:08 AM   #2
36rgtop
36rgtop's Avatar
Default Re: Help with a measurement
Early or late 21 stud ?
36rgtop is offline   Reply With Quote
Old 05-24-2022, 09:10 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
For which year/model 21 stud engine?
John
Old 05-24-2022, 10:54 AM   #4
rockfla
rockfla's Avatar
Both, I am making Blank off plates for pressure testing SO I would need both!!! If possible!! Thanks!!!
Old 05-24-2022, 12:18 PM   #5
Flathead Fever
Flathead Fever's Avatar
We used to make gaskets at work. Just lay it over the piece and take the round end of a small ballpeen hammer and tap over the bolt holes and it cuts them out like a hole punch. Same with the impeller hole and around the outside edge. That's how we kept equipment in service when there were no gaskets available. You can even use Gasgacinch to hold the gasket in place, it will let you peel it off when you're done.
Flathead Fever is offline   Reply With Quote
Old 05-24-2022, 01:06 PM   #6
Zeke3
Zeke3's Avatar
You are asking about the dimensions for the water inlets on the early 21 stud engine aren't you? I am sorry, I can't help with those dimensions. My 1937 21 stud engine has water pumps on the front, so the block off plate would have to be the shape of a water pump gasket without the big holes for the water inlet and the impeller.
Zeke3 is offline   Reply With Quote
Old 05-24-2022, 02:02 PM   #7
rockfla
rockfla's Avatar
Zeke3
Correct, BUT would like the BOTH early and late so I will have both blocks covered as I need it for 32,35 & 37 personally and will be covered for any friend who needs to use them in the future. And correct NO large center hole, just the bolt centers and a relative OD to cover the hole and bolt circle
Old 05-24-2022, 02:16 PM   #8
Mart
Mart's Avatar
37 (if late) would be the same as 59A if it helps at all.
Old 05-24-2022, 03:11 PM   #9
DavidG
DavidG's Avatar
Robert,
For '32-'36 block-off plates picture an elongated diamond shape 2 1/2" wide by 4" tall with the two holes for the 3/8" bolts 2 7/8" apart on center. Post '36 block openings are larger, but I've not one handy to measure; sorry.
Old 05-24-2022, 03:52 PM   #10
rockfla
rockfla's Avatar
Originally Posted by DavidG View Post
Robert,
For '32-'36 block-off plates picture an elongated diamond shape 2 1/2" wide by 4" tall with the two holes for the 3/8" bolts 2 7/8" apart on center. Post '36 block openings are are larger, but I've not one handy to measure; sorry.
Thank you very much David, that is exactly what I was looking for, now for the 37 block???
Old 05-24-2022, 04:19 PM   #11
DavidG
DavidG's Avatar
Robert,
In case you do not get a better answer, here's a scan of a '37 + water pump gasket. The large opening hole is 2 7/8" in diameter. The two 3/8" bolt holes nearly, but not quite, opposite one another are 4 7/8" apart on center.
Old 05-24-2022, 08:33 PM   #12
KiWinUS
KiWinUS's Avatar
Robert you could use the factory block offs for the 37 blocks. I have extras if you need a set.
Old 05-25-2022, 06:35 AM   #13
Terry,OH
Terry,OH's Avatar
I also have an extra pair of block off plates.
Old 05-25-2022, 06:50 AM   #14
rockfla
rockfla's Avatar
That would be great to have, I will take a set from one of you guys......PM me a let me know what you want for your set. Thanks a million!!!
I WILL BE AT THE EASTERN NATIONAL IF Either of you are going, I can meet you!!!!
Old 05-25-2022, 11:51 AM   #15
Zeke3
Zeke3's Avatar
In case you still want the dimensions, here is a drawing based on a gasket. The extra width is needed at the bottom to cover a small water hole.
Old 05-25-2022, 12:52 PM   #16
rockfla
rockfla's Avatar
Thank you Zeke3, I saved it at well...good to have just in case!!!!
