05-21-2022, 03:54 PM | #1 |
clutch wont disengage
have t-5 conversion behind 1953 flathead pickup engine putting in 1935 pickup. Using chassis engineering pedals. Speedway kit using original fork and shaft. Setting up clutch cable. Put arm on end of fork shaft to operate by cable. Can not get clutch to disengage. Throw out bearing travels almost a inch before contact to pressure plate fingers. A m using 3 finger pressure plate. Is that a normal amount of travel before contact with pressure plate. Looks to put fork at forward angle before any attempt to disengage. Seems like i would be losing leverage. When i torque pressure plate fingers are drawn in which i assume is correct but could they be to much? Parts are all and new using 10.5 pressure plate and clutch disk.
05-21-2022, 04:50 PM | #2 |
Re: clutch wont disengage
To get the clutch to release you need to reduce the 1 inch free play you have. The throw out bearing needs to be as close as possible to the fingers on the pressure plate but not touching. Once you reduce the amount of free play you now have the clutch will release.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-21-2022, 07:00 PM | #3 |
You may have the wrong throw-out bearing. They come in "short" and "long" configurations. You may need a LONG T/O bearing. Coop . |
05-21-2022, 07:09 PM | #4 | |
The fork should contact the bearing just a few degrees before the center of its arc. Bill |
05-22-2022, 10:46 AM | #5 |
The type of clutch and throw out set up for flatheads is important. Adjustable fingers help but many replacements aren't adjustable. The Centerforce diaphragms clutches have bent fingers and add on spacers.
I stick with conventional type mechanical linkages on the old Fords. Cables and hydraulics go too far for me. The fingers have to clear the input shaft and make good contact with the throw out bearing. Last edited by rotorwrench; 05-22-2022 at 11:05 AM. |
05-22-2022, 10:56 AM | #6 |
05-23-2022, 12:14 PM | #7 |
Is it possible to incorrectly install throw out bearing fork on shaft? Hole looks centered but is it off set? I know curved side goes against bearing. Will flipping shaft make a difference? Will it put bearing closer to pressure plate fingers?Throw out bearing travels almost a inch before making contact with pp fingers.
05-23-2022, 12:33 PM | #8 |
hold the clutch arm with a pair of plyers, using the plyers to move the release arm against the fingers on the clutch and adjust the pedal arm linkage to fit this--in other words remove all of the free play that is causing the long pedal movement, then let the arm come back to let it move just off fingers
