11-17-2020, 04:56 PM | #1 |
Cubic inch question
I have a Ford 8ba that has been bored .040 over and has a Merc. crank. What cubic inch does this come out to? Thank you and sorry for my ignorance.
11-17-2020, 05:16 PM | #2 |
Re: Cubic inch question
261.8 (let's call it a 262).
11-17-2020, 05:30 PM | #3 |
That tubman sure knows how to punch a calculator....on the money! DD
11-17-2020, 06:52 PM | #4 |
Yeah, but I didn't have to look up the mathematical formula required. When I was in college taking physics, calculating devices (slide rules in my day) were OK during tests. They were checking your knowledge of Physics, not your math abilities.
11-17-2020, 07:27 PM | #5 |
I've known that formula (by heart) since junior high. And I do it the ".7854" way. DD
11-17-2020, 08:21 PM | #6 |
11-17-2020, 08:32 PM | #7 |
So is my .080 over gonna be 269?
11-17-2020, 09:16 PM | #8 |
268.33
(pi X bore radius squared x stroke x 8)
11-17-2020, 09:38 PM | #9 |
Thanks cad, guess I better say 268.
11-17-2020, 10:13 PM | #10 |
Thanks, that's what I came up with but was told it was wrong.
11-18-2020, 01:35 AM | #11 | |
OK, "0.7854" is a function of pi, accurate to at least four decimal places. 0.7854 = 3.1416/4 or (3.1416 divided by 4). Example: Bore X Bore X Stroke X .7854 X 8 (cyls.) = Cu. In. Your FIRST Example: Bore = 3.1875 + 0.040 = 3.2275 Stroke = 4.0 Constant = .7854 Number of Cylinders = 8 __________________________________ So: 3.2275 X 3.2275 X 4 X 0.7854 X 8 = 261.80224 |
11-18-2020, 02:00 AM | #12 |
I do it slightly different.
I punch in the bore (3.2275), then I hit the squared button (² ), after that, I multiple by .7854, then times stroke (4) and finally, times 8 = 261.80225148 Darn, I got a different answer, what happened One of the nice things about using .7854, is that on number pads, it is the top, left hand corner keys. Makes it a little easier for me.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
11-18-2020, 03:04 AM | #13 |
It would take me 10 years to understand why you square the bore measurement.
11-18-2020, 03:38 AM | #14 |
You square it because you want the area of the cylinder.
Area of a circle is Pi r squared. Because we know the bore rather than the radius, we have to use the alternative formula that uses the diameter. Area of a circle is pi d squared all over 4. (over = divided by) Volume of one cylinder of a stock 239 for example is: 3.1875 * 3.1875 * 3.1416 / 4 Which equals 7.9798. Unit is square inches. Volume of a cylinder = area * length. So 7.9798 * 3.75 = 29.9242. Now the unit is cubic inches. So just shy of 30 cu in. Volume of the engine is volume of one cylinder times the number of cylinders. So 29.9242 * 8 = 239.3936 Rounded to 239 for ease of reference. I used a known engine because we are already familiar with the answer. In the examples above the shortcut is to use pi/4. 3.1416/4 = .7854. The above formulae are completely universal and by using centimeters the volume in cc can be calculated. Mart. |
11-18-2020, 04:29 PM | #15 |
thanks, fellas. Terry
11-18-2020, 05:20 PM | #16 |
In my dotage now, my sliderule days are long forgotten, but you can do more today with a $6.99 drugstore calculator than the best sliderule ever made.
My old sliderule was never much good for making straight lines anyway, with that bumpy thingy right there in the middle. I will say though, I had a round one once that helped me earn free pizza in my sports car rally days. (Back in the day, you'd have to tell them if you didn't want anchovies.) Come to think of it, I guess I could have used my sliderule to determine how much beer was in a "'Yard of Beer' Stein".
Alan |
11-18-2020, 05:25 PM | #17 |
Mart,
With respect, if we know the bore diameter, we automatically know the radius as it is one half of the diameter. |
11-18-2020, 05:33 PM | #18 |
Who says one only remembers 5 minutes of what they learned in 5 years of college?
You guys have proved them wrong
Thanks Andy 1952 F1 |
11-18-2020, 05:52 PM | #19 | |
Aw, I retain very fond memories of a few 5 minute sessions in college!
Alan |
11-18-2020, 06:05 PM | #20 |
