Old 08-13-2016, 03:29 PM   #1
firechief5215
firechief5215's Avatar
Default Having a Horn Issue
We have a Spartan horn , It will not turn or at least you have to help it. I pushed the horn button ,I took a wood dowel and help it get started and it went about 8 or 10 revolution's and stopped. I have read the threads about spraying it and checking ground witch I did even oiled it and no better, Am I missing something Thanks
firechief5215 is offline   Reply With Quote
Old 08-13-2016, 04:00 PM   #2
midgetracer
midgetracer's Avatar
Default Re: Having a Horn Issue
If you ground the blue wire connection to a solid ground and the horn does not blow well, the problem is probably in the Horn. I wouls suggest cleaning the commutator, checking the brushes and if that fails, back off on the adjuster and see if it runs fast then. If this fail, you may need a horn rebuild.
midgetracer is offline   Reply With Quote
Old 08-13-2016, 04:36 PM   #3
1crosscut
1crosscut's Avatar
Hook it up with a couple of jumper wires from the battery. If it sounds well then the problem is in the wiring of the car. If not then the trouble is with the horn.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 08-13-2016, 08:54 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
My friend's horn barely turned, so I backed out the adjustment screw and held fine sandpaper on the commutator as it spun. After a few seconds of this the speed picked up and I adjusted the screw back in for proper sound. The commutator didn't look bad, but the fine sandpaper did the trick.
Old 08-14-2016, 12:04 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
This may help as well,
http://www.modelabasics.com/horn.htm
Old 08-14-2016, 08:49 AM   #6
firechief5215
Thank you I will give this a try and see what happens
Old 09-22-2016, 08:40 PM   #7
Tom Wesenberg
Yes, what 1930 coupe just said. I've felt some horn buttons get very warm after just a few seconds of blowing the horn. A poor connection causes heat.
Old 09-23-2016, 06:43 PM   #8
Ray in La Mesa
A temporary fix is to push down hard on the horn button and rotate it back & forth a number of times, cleans the carbon off the contacts, till you can disassemble the button to clean the contacts right.
Ray in La Mesa is offline   Reply With Quote
Old 09-23-2016, 07:33 PM   #9
Tom Wesenberg
That's what I had to do to my 28 when I bought it in 1999, and it's been working fine ever since.
Old 09-23-2016, 07:46 PM   #10
Joef21
If it turns out to be the ground on the horn switch, use a electronic relay available thru Seders.
Joef21 is offline   Reply With Quote
